Old 09-10-2013, 08:28 PM
Vegaman_Dan Vegaman_Dan is offline
Default Hot Metal Glue Therapy - it's the best! New Member
That's right, hot metal glue therapy, aka welding. There's something magical about fabricating things in your garage. The ability to just take an idea in your head and visualize how to approach it.
Directions? Forget them. You're in control now. Directions are more of a suggestion than a rule. Maybe you have a better idea how to do something. Try it out- you may discover something new nobody else has come up with. And when you do, share the knowledge with others.
The confidence that you can grab some metal, weld bits together and modify as you go. Need a mounting tab? No problem, just add it here. Want to make a welding cart to your own desire? Easy!
Perhaps there's no better words to describe the pride and satisfaction you can ever feel in the garage than this:
"I built that."
Vegaman Dan - If it's not broken, then you're not trying hard enough.
