Old 08-31-2011, 12:55 AM
Ismar1984 Ismar1984 is offline
Default Hi from Australia
Hi, my name is Ismar and I am from Melbourne, Australia. I am currently building an Australian 1970 Ford Fairlane, with all the chassis work almost done it time to move onto the sheet metal. So i though i'd join this forum to gets learn some tips and trick.
Ismar
Old 08-31-2011, 06:55 AM
Toprodz Toprodz is offline
Welcome aboard Ismar good to have another from Melbourne here, sounds like a cool project, what have you done with the chassis?? Tubs ?? anyway there is plenty of great people around here to learn from.
Kind Regards
Toprodz
Old 08-31-2011, 09:38 AM
Welcome to Allmetalshaping Ismar!
Do you have any pictures of your project?
Old 09-04-2011, 11:45 PM
I am basically building a new chassis for it, just keeping the original front chassis rails but with a tubular double wishbone front end and a 4 link rear. Here are some pictures, i know the cross member looks a bit too beefy but once i mock up the engine it will be trimmed to suit and the exhaust will go through the frame. This is my first project so it has been a steep learning curve and everything is taking allot longer than i though.
Ismar
Old 09-07-2011, 06:50 AM
Hi Ismar
Thats is starting to take shape, the rails look similar to the ones McDonald Bros racing sell, I spent a couple of years working for them doing similar projects like yours, are you welding the x into the middle of the body or is that just bracing ?? Would love to have a closer look one day, if I can help answer any questions give me a ring 0412 81 1932, I live in Coburg . Peter
Here is McDonalds website in case it intersts anyone
http://www.mcdonaldbrosracing.com.au/contact.php
Kind Regards
Toprodz
Old 09-07-2011, 07:23 AM
Welcome to the site Ismar
Old 09-07-2011, 06:29 PM
Yes, the rails are McDonalds brothers and they made the 4 link arms for me as well, though i am using my own brackets as the arms are not equal length and the 30.5' tyres posed some problems in regards to arm positioning on the diff housing.
I will be welding the X-member in but it will have through holes for the exhaust and the centre section will notched to accommodate the transmission. Do you think its a bit of overkill? I really don't want to have any issues when it comes to torsional testing for engineering and the engineer seemed pretty happy with the design when i showed him the CAD model.
It'd be great if you could have a closer look one day. i'd love to get some input from someone with experience in chassis fabrication.
Ismar
Old 09-09-2011, 01:57 AM
The issue I think that you are going to have is that the X rails look to be 75mm x 50mm (2X3 for our american cousins) is that you are going to end up with a pretty high tunnel through the car going by the picture showing how low the car is sitting with the wheel, in the wheel arch, as the height of the pinion on the diff looks like it will be higher than the floor at the rear, also with the car sitting that low you won't be able to run the exhust under the car, so it is going to have to go through the rails, so if are running a 2 1/2" (63.5mm) exhust pipe there is not much room left in the x pieces to put holes through them for the pipes, and have clearance around them, if there was it would make them very weak.
I am happy to come look and discuss the options to make it work
Kind Regards
Toprodz
Old 09-12-2011, 05:27 AM
thanks for the input Peter, you're right the tunnel will have to sit pretty high but i am not too fussed with that as i only plan on having two seats in the back.
For the rails i am using 100x50mm RHS so that should help a little with the exhaust going through, I also plan on doing an oval exhaust so as to minimise the amount of material taken out in one direction.
I'll give you a call later in the week, I am in Rosanna so not very far from you.
Thanks,
Ismar
Ismar
