Old 12-07-2023, 02:32 PM
stueeee stueeee is offline
Default Newby from NW Kent UK
Hi to all, I'm a retired engineer these days and have been messing with old cars and motorbikes since I was a young teen. These days I have a well equipped workshop and enough ongoing projects to last till I'm about 120 years old. The particular reason for wanting to join this forum is that one of my projects -a 1930s single seat racer needs a new tail to be made in Aluminium. I have an English wheel here but at the moment, not the skill to make the best use of it, I am determined to change that, although it is likely that I will turn a lot of perfectly good ali sheet into scrap metal first.
Stuart
Old 12-08-2023, 07:46 AM
dwmh dwmh is offline
Welcome to the forum Stuart. You should find all the help you need here.
David Hamer
Old 12-08-2023, 08:08 AM
Welcome,
Keep in mind, you also turned a lot of perfectly good paper into scrap learning to write. That and the current quest should not be considered a waste of either time or materials if responsibly approached!!
Marc
Old 12-08-2023, 08:14 AM
Mike Whelan Mike Whelan is offline
Hi Stuart,
I'm also a retired engineer (i'm 78 years old).Several years ago I built a small English wheel (22 inch throat). I watched a lot of videos and read a lot but in the end I decided that personal tuition was needed. I went to several courses in the UK and found Geoff Moss (ex Aston Martin) very good. He is located in Devon.
Mike (nr Trier, Germany)
Mike Whelan
Old 12-08-2023, 08:53 AM
MetalShaper of the Month April 2020, September 2021, November 2022, July 2024
Stuart, don't take your pants down when the ford is still far away...
Make several smaller trial pieces. Try to work so that the sheet is always soft. A paper template will help a lot. It will show you where to lengthen the fibers and where to shorten them. Show your project and get lots of advice. You can then choose the path that will be good for you.
Old 06-17-2024, 11:43 AM
Originally Posted by Mike Whelan View Post
Hi Stuart,
What a coincidence... Since writing my intro I have also spent 5 days with Geoff Moss at MPH Motor Panels, now located in Cornwall. Learned a huge amount during my time there. Also learnt that I have a huge amount to learn. Here's what Geoff was just finishing when I arrived.
Here I am using the Ranalah wheel that's in the photo above.
Here's my wheel back at my workshop.
Really enjoyed my time at Geoff's, there's self catering accomodation on site which like the course, was quite reasonably priced.
Stuart
Old 06-18-2024, 06:11 AM
That looks a really nice wheel, Stuart. You won't be able to blame your tools, with that one.
David Hamer
