Old 04-10-2020, 12:14 PM
Default Geometry - Helix (Helicoid)
From Wikipedia:
"Helix
A helix, plural helixes or helices, is a shape like a corkscrew or spiral staircase. It is a type of smooth space curve with tangent lines at a constant angle to a fixed axis. Helices are important in biology, as the DNA molecule is formed as two intertwined helices, and many proteins have helical substructures, known as alpha helices. The word helix comes from the Greek word ἕλιξ, "twisted, curved".
(A "filled-in" helix for example, a "spiral" ramp is called a helicoid.)"
DNA - single
DNA - double
"Alpha Helix"
https://en.wikipedia.org/wiki/Alpha_helix
"Archimedes screw" shown in operation
http://www.incois.gov.in/Tutor/scien...re10/screw.gif
Auger
HELICOID
Helicoid - Spiral stair:
The designer developed his stair section, thus:
Made the shape into a heavy wood mock-up, maquette or "buck."
2X6 + 1in ply glued and screwed, then CNC milled in appropriate router-machine:
And with some hammering here and there .... boom - whacka-whacka ....
Old 04-10-2020, 03:52 PM
RatRockx's Avatar
RatRockx RatRockx is offline
MetalShaper of the Month July 2013, Feb 2018
The front side of this lectern has a helix shape. When I made it I found that it is pretty much a reverse. If you stretched one side in a wheel you would rotate the panel 180 degs and stretch the other side. For a helix you flip the panel so that it's rotated and upside down. Pull up a bit while wheeling and you'll get a helix.
Joris Rockx
www.rockx.net
*** Elbow Grease & Midnight Oil ***
Old 04-10-2020, 05:55 PM
Attachment 56049
Jo Joris,
Ja, I sure had to know more about linear shaping to put this job in a twist.
But this was not quite like other familiar reverse weirdness .....
Old 04-10-2020, 08:21 PM
In the beginning ...
I had to grasp the nature of a shaped panel that twisted.
And yet remained flat ...
So, the panel started out flat. This part was easy.
I laid out my lines of shape, and I made a plan.
And I worked my plan.
And I stuck to my plan
Check fit.
hammer hammer ....
Check fit
...and so on .....
... not there yet ....
Old 04-11-2020, 03:19 AM
Fascinating work there, Kent. Definitely not an 'everyday' job!
Did the sheet stiffen up some as the shape was induced? Also, did the final product need to be smoothed, and if so, how did you planish, or intend planishing, all the little hammer marks?
TX
Manny
Old 04-11-2020, 01:55 PM
No Manny, not an everyday job - except when it happens everyday .... for weeks on end ...
When the shape wilds the panel sandbags are used to calm things down.
Yes, the 1.5mm (.063) steel hardens with hours of hammering.
And yes the panel flip-flops quickly ... snapping hard enough to bite unwary fingers.
Yes, it is a fight to push-pull the 40 lb 20sq. ft panels forth and back, accurately - with the added weight of the bags ...
and with all that the panel has to be physically twisted to align nicely with the dies when hammering .....
Oh ... planishing ... yeah I have die sets for that sweetness ...
Old 04-14-2020, 04:19 AM
touringgarage touringgarage is offline
MetalShaper of the Month September 2014, April 2019
this is absolute world class.
end of the flagpole
incredible
Bernhard
Old 04-14-2020, 11:41 AM
end of the flagpole
incredible
Vielen dank, Bernhard!
Old 04-14-2020, 01:02 PM
While the geometry lesson may be lost on me, the ability to think (and work) big is obvious and impressive. Not to mention... that just looks like hard work!
Interesting. Looks good.
Matt
Old 04-14-2020, 07:50 PM
Thanks Matt.
It feels like hard work, too.
Planishing "seasick" contours ... was a challenge.
Had to come up with a "sailor" die set.
Something that can sail smoothly across the waves ...
Navigating rough spots ...
smooth sailing ...
And so I modified one of our #6 air motors to hit softly ...
and it changes out in a few seconds, uses the same air pressure, and on we go ...
