Old 05-09-2009, 04:37 PM
Default 41 Chrysler New Yorker Coupe
I will start a new thread for my project car.
I'm building a 1941 Chrysler New Yorker 2 door coupe.
I'm installing 37 Ford headlights and shaping the front end similar to a Willys.
I started by cutting off the headlight on the drivers side and brought the metal in to meet a template of the headlight.
Coated it with bondo to create a buck to take a pattern from.
Thanks for looking,
Old 05-09-2009, 04:48 PM
Default Mockup
I got both sides done with the outer pieces and then had to mock up one side to take patterns and to see if I liked the shape.
I made up another piece exactly as the outside pieces and tacked it in place.
A little bit of "Burt" buck with some chicken wire to hold it in place and I got the shape.
A little bit of metal finishing.....
And that's where I am now.
Lots more to do , but I'm in no rush.
Thanks for looking,
Old 08-18-2009, 05:51 AM
Default Welding Panels
Well I tried welding the 2 panels together and did not bad.
I TIG weld by trade, so that is not an issue. Going about it the right way with the stretching of the welds to get the shape back and trying to metal finish smoothly is new to me.
anyway....pics.....
Marked with the pattern for trimming...
Tacked together.....
A few 1" welds....
Penetration on the back side. The peening marks from stretching the previous welds showing....
You can see the weld line. The filler rod is slightly different color...
Still needs metal finished but I'll do it later...
Thanks for looking,
Old 08-18-2009, 07:07 AM
NICE work Pugsy! Did you take some of those photos at Ken Burt's shop? It sure looks like his ewheel in the background of the second photo.
Old 08-18-2009, 08:36 AM
Jacob's Avatar
Jacob Jacob is offline
Thanks for sharing your progress. Looking forward to more posts.
Old 08-18-2009, 09:09 AM
Thanks Kerry.
That's the wheel I built right after the first time I went to Ken's.
Very similar to yours as that was basically the only one I saw before making it.
Old 08-18-2009, 03:53 PM
Nice job on the panel. Please post more pictures as the progress continues.
Old 08-18-2009, 04:20 PM
jhnarial's Avatar
jhnarial jhnarial is offline
Looks good.
Did you tack it every inch and then filled in-between the tacks?
It came out so good I am just wondering what your procedure was.Could you go into a little more detail on how you did it.
Keep the posts coming.
Johnny Arial
Please stay on topic.
Old 08-18-2009, 06:58 PM
SumTingWong's Avatar
SumTingWong SumTingWong is offline
Wow..
That's craftmanship.
BTW- What's the blue tint on the sheet metal as you're finishing it?
Rob
Old 08-19-2009, 11:54 AM
Thanks Guys.
The panel was tacked every 3/8" or so. I started at one edge and tacked my way around. This helps to keep it pretty much level as you can lift up either side as you go around. Eventually the two pieces overlap and you can't do any more tacks without stretching what you've done already.
After tacking, I flipped it and peened it on a flat dolly stretching the tacks and getting the two surfaces flush with each other. Then just welded with TIG rod about 1" long welds spaced about 2" apart. I don't think it really matters much as the key was in the stretching of the welds afterwards. I read that somewhere and it worked well. I believe the penetration is key as all the raised filler rod is getting ground off on both sides. Then some grinding,peening,slapping, sanding, filing, and a bunch of hours later my first decent body weld finished.
Thanks,
