Old 03-23-2021, 02:31 PM
chrisnz chrisnz is online now
Default 41 Chev pickup build
I've owned this 1.5 ton cab and chassis "41 chev for around 11 years. I've been a little reluctant to start it, as it just seemed like a large rust job. Anyway, I've started it.
What I plan on, is to drop the cab onto a half ton chassis, channel the cab 3", roof chop 2", internal hinges and remodel the front sheetmetal. It took me around a week to dismantle the cab, so it could go into the citric bath. (Thanks Marcus) That gave me relatively clean steel to work with. I've started with the floor, which I've made as the original didn't suit my purposes.
Attachment 59177
This is 2mm electrogalv, which is folded up to suit the seats.
Started on the under floor sub frame
Chris Woolley
Old 03-23-2021, 06:30 PM
MetalShaper of the Month Dec. 2016, Sept 2019
Hmm, it appears that this picture was taken down under.
Old 03-23-2021, 09:31 PM
onya onya is offline
Close enough mate NZed
Leigh,
Old 03-24-2021, 11:11 AM
What gave it away? The welder
Chris Woolley
Old 03-24-2021, 11:50 AM
In New Zealand, vehicles have to be certified to go on the road. This pickup will be classed as modified production.
Attachment 59189
Incorporated into the floor, are doubler plates for the seats and seatbelt mounts
Attachment 59190
Once I'd welded the floor up, the subframe was then welded to the firewall mount.
Chris Woolley
Old 03-25-2021, 04:23 AM
Looking forward to following this build.
Old 03-25-2021, 10:09 AM
I'm certainly not computer literate. Here are the missing photo's. A lot of my other photo's were coming out upside down, so I guess you won't see them
Crush tubes in for the rear cab mounts
Chris Woolley
Old 03-26-2021, 08:08 AM
dwmh dwmh is offline
MetalShaper of the Month May 2018
Hi Chris, hope I'm not stating the obvious, but you don't want to be breathing galvanised steel welding fumes.
Looks like you're going to be busy for a while.
David Hamer
Old 03-26-2021, 02:11 PM
No precautions taken. Do I need a respirator or an exhaust fan? I will be busy, but I just focus on the day, not the entirety
Chris Woolley
Old 03-27-2021, 09:49 AM
Hi Chris, I'm no expert, so I have copy and pasted from a welding website.
When welding galvanised steel, a respirator is required so that the zinc oxide fumes from the galvanising are not inhaled. Inhalation of zinc oxide fumes can cause metal fume fever. This acute overexposure to zinc oxide through the respiratory system causes flu like symptoms that can be severe.
David Hamer
