Old 02-17-2023, 07:18 PM
Oxweld's Avatar
Oxweld Oxweld is offline
Default Magnesium Flux
Magnesium welding and brazing flux seems to have been discontinued by superior flux, and everyone else too it would seem... My old welding manuals state that some aluminum welding fluxes may be suitable for welding magnesium. My question is which flux(es) are suitable, or will I have to guess and check as I go?
Jameison, gas weldor.
Old 02-17-2023, 08:01 PM
If he doesn't reply in this thread, contact Kent White (TM Technologies). If anyone will know what's still available he will.
Old 02-18-2023, 08:46 AM
Default Edited: Mg flux, TIG welding
Thanks Chris.
Hi Oxweld,
I'm not surprised Sup.Fl. is no longer supplying Mg flux.
Mg is flammable and cannot be extinguished, once going.
Prices for Mg are going strato.
The TIG was specifically designed for welding Mg, back in 1942, by Northrop.
... Because of flammability. "Cinderella of Metals" pretty much says it.
(Jack Northrop's YB49 ... https://www.youtube.com/watch?v=eG4E55Havyc )
Someone somewhere may have a jar of Mg flux sitting on the shelf....??
(Welding Mg has not been a problem presenting itself in my own little world, so I have not devoted any energy to a "flux-welding" solution for it. TIG welding Mg is not a problem ... (forgings are best done pre-heated.))
-end-
Old 02-18-2023, 02:28 PM
Hi,
I have a little bit of Superior magnesium flux left and I would be interested in more. I have Oxy/Hydrogen welded Magnesium AZ31B with excellent results. It is easy to get full penetration and a beautiful weld bead appearance on both sides of the panel. I know the Superior Flux Company has been open to mixing any of their fluxes if ordered in high quantity. I would be interested in purchasing more if guys are interested in going "in" on it. If you experiment with aluminum flux, let us know the results.
The welding of the material is fine, regardless of process, as long as good precautions are in place. Magnesium fillings and dust from grinding is the larger danger involved with this light weight material.
Flux clean up is ultra critical to prevent the development of corrosion. I use hot water, soap, brush and clean, clean, clean. Once the part is finished, I use MAG-COAT "Magnesium treatment solution, Chromium Trioxide) to prevent/slow down the future development of corrosion. Like my High school shop teacher Frank Maross said, "You can't stop material from turning back into it's natural state, all you can do is slow down the process."
Bill Tromblay
Old 02-18-2023, 09:12 PM
Oxweld's Avatar
I have some of Kent's aluminum flux, and I think I will order some of Superior's Anti-Borax aluminum flux as well, I will give each a try with some scrap mystery magnesium and post my results when I do.
I would go in on a group magnesium flux purchase if you did organize one.
Old 02-18-2023, 10:51 PM
Would there be any benefit getting an analysis of the various chemicals involved in a good mag flux and then paying a chemist to make some? Perhaps a group buy?
There are sites to find freelance folks in all fields
Example:https://www.upwork.com/hire/chemists/
Old 02-19-2023, 01:44 AM
Oxweld's Avatar
Not much need to I think. Mg flux is usually a mix of some/all of the following: Sodium Fluoride, Lithium Chloride, Calcium Chloride, Sodium Chloride, & Potassium Chloride. Just ratios needed, could experiment and probably make a decent flux yourself.
Or, follow this recipe from 1942: https://patents.google.com/patent/US2396604A/en
Old 02-19-2023, 06:48 AM
That's where a chemical analysis of some known good flux would be helpful IMO. It would give the %'s.
Old 02-19-2023, 08:33 AM
The presentation of the goal of the invention is educational:
A fluxcomposition, to be useful in the welding I of magnesium-base alloys, must possess a considerable number of characteristics not ordinarily found in fluxes employed in welding other metals. It must be capable of being applied in a variety of ways, as a dry powder, as a core of the filler rod, or as a paste. It should flow readily overv the molten weld metal to protect it from oxidation by the air and should exert a solvent action on any magnesium oxide present to insure It should not the production of clean welds. evolve gases on heating, react with hot magnesium to cause pitting, or introduce metallic impurities into the weld metal. It ought preferably to have a density approximating that of molten magnesium, so that it will not remain embedded, even to a very minor extent, in the solidified weld metal, and thus to produce flux inclusions giving rise to serious corrosion. In addition, it should be easily removable from the welded piece, as by wire-brushing or washing, and should have no adverse chemical effect on the treating solutions in which finished magnesium articles are conventionally dipped to form protective surface coatings. No flux having all these qualities has been available heretofore, the fluxes actually used being at best compromises designed to exhibit undesired properties to the minimum extent possible.
Marc
Old 02-19-2023, 12:49 PM
Overkill Overkill is offline
Default Halibrands
Many years ago I had some Halibrand magnesium wheels repaired in Colorado. The name of the company has been lost to time, but I googled magnesium wheel repair and found multiple companies offering the service. They might be a good source of flux information.
