Go Back   All MetalShaping > Miscellaneous stuff you need to know > Comments and Suggestions
Old 06-16-2023, 10:15 PM
Carl Hungness Carl Hungness is offline
Default How To & What Tubing Does Runge Use
I've watched several videos showing the cars Runge has built and it appears as though he is bending (aluminum) tubing that is basically the shape of his bodywork, and ultimately welding aluminum panels to the tube. Thus he has to be using aluminum tubing and it sure seems to be formed precisely to his varying shapes. I wonder: What tubing is he using, and method of bending to get the shapes?
Carl Hungness Madison, IN
Old 06-17-2023, 03:05 AM
Not sure, but those that aren’t following him, he has started a new series of Videos that are quite informative.
https://youtu.be/pLATVOYzOKY
ærugo nunquam dormit
Old 06-19-2023, 12:53 PM
From what bits I know about using aluminum tubing for structures, I'd use 6061 T6.
I'd probably use the old water-fill maneuver, which works for bending up steel roll-cage tubing shapes, anyways.... at least in my neighborhood.
Old 06-19-2023, 11:43 PM
pato1 pato1 is offline
water?--only have heard sand....
Pat
Old 06-20-2023, 11:02 AM
s'okay ....
Sand .... um well....
Mercury, serrobend, pitch, ice, and water are the ones I know, fwiw.
Incompressible pourable stuff - sealed tightly.
Old 06-20-2023, 11:42 AM
s'okay ....
How do you seal the ends when using water? Sounds easier than sand. Are you doing it cold?
Old 06-20-2023, 03:40 PM
Hi Chris,
brrr-cold.
https://www.swagelok.com/downloads/w.../MS-01-140.PDF
(never seen this toobmethod mentioned/used outside my small circle, 'cept for the Old craftsmen I workd with)
(ps: - Never have blabbd this tech around ... else be common toolbox chitchat .....)
(btw, one-piece titanium hollow ball? )
Old 06-20-2023, 06:32 PM
Hi Chris,
brrr-cold.
Thank you Sir.
Old 06-20-2023, 08:11 PM
When I hear sand - it is usually one of these doing the packing:
https://tools.cp.com/en/products/per...s/sand-rammers
Old 06-21-2023, 07:21 AM
I have used mine for years to wedge old Roma clay to the proper consistency. It has become one of the most important tools in my studio- https://www.youtube.com/watch?v=vtB5WYZ4_94
