Old 10-07-2010, 08:55 AM
Default Pexto 241 lever shear
Picked this up at my local candy store (Dempsy's) along with another punch . I have a punch disease
I cant wait to try it out , as much as i use my corner notcher to make brackets this will do much heavier metal . It will also cut both ways on the blade ... if you look at the blade the right side goes up a little so it will cut on both sides , it will do inside corners and start in the middle of the sheet . The table was broken so i took it off to fix it.
James
Old 10-07-2010, 09:49 AM
Looks like it will work fine
I need something like that in my arsenal
Old 08-01-2013, 09:55 AM
I just want to revisit this thread . After cleaning and resharpening the carbide blade and using it for 3 years .This has become one of my favorite tools ! It will cut a straight line for days the blade is 9 " so it will follow itself. It will also cut 11 ga . (.125) . It said 12 in the book but old pexto was always underrated. If you ever see one buy it you will not be disappointed .
James
Old 03-13-2014, 04:04 PM
Adair Orr Adair Orr is offline
That looks like a very handy shear. Nice detail with the back rake on the straight blade.
-Adair
Adair
Old 03-15-2014, 07:24 AM
It is , i still us this tool almost every day
Old 06-04-2014, 10:54 AM
bimmer1980 bimmer1980 is offline
Default 241 shear
James-- Nice shear. I bought mine on an impulse buy here in York, PA and it has been so handy! I haven't really seen another one in person.
Glad you found yours as handy as I have found with mine....
The one I bought did not have the front table or the back stop. But it did have the cast iron legs...
Brad
Brad
Currently working on a new garage for the tools...
Also a member on garagejournal.com
Old 06-08-2014, 05:14 PM
Attachment 28154
Attachment 28155
Brad
These shears are real nice for making clean accurate slits for louvers. Then you just press in the shapes.
Old 07-04-2014, 12:43 PM
Jonathan Hanson Jonathan Hanson is offline
Default Pexto 241-C converted to power shear
photo-7.jpgHey guys,
Thank you very much for posting your information in this thread, it doesn't seem like there is much information out there on these machines. I just picked mine up at a barn sale for $70. It looks like someone along the way tried to convert it to a powered unit. The shaft that cycles the shear is missing though.
Have you guys ever seen one of these units converted over to power before? Do you know where I can find some more information or pictures showing how the ex-centric works for the blade? I have a few ideas on how I can machine a shaft that might work, but I don't even know how the internals actually looked when it was a power or manual unit.
If you guys have any info or advice that you could help me out with, I would greatly appreciate it.
Thank you,
Jon
Old 08-06-2014, 01:36 PM
well that is interesting......
I wonder if the previous owner broke the shaft by trying to shear something too big or just didn't get it done....
I don't really know what it looks like. I would have to pull the front plate on mine to see what it looks like. I'll be out of town for the next while, so I won't have a chance to do that...
I'll check this thread after awhile to see if you have it figured out. If not, I can see about looking at mine closer for you...
Brad
Old 06-24-2015, 02:48 PM
Just revisited this thread . I cant say enough about this shear i use it constantly a powered one would be even better but probably pretty dangerous.Jonathan did you ever get yours working .
