Old 02-06-2022, 08:08 AM
sfm1951 sfm1951 is offline
Default Radius brake
Does anyone have a radius brake, or made one? If so could you PM me a pic of the the adjustment bolts for raising and lowering of the different size radius bars and the follow tube? I want to make one similar to a radius brake sold by trick tools. I can't afford the price of a new one . Thanks in advance, Steve
never-ever kick a fresh turd on a hot day!
Old 02-07-2022, 03:11 AM
Hi Steve. If you need to make radius bends on the smaller side (2" and less) you can use a conventional brake with a tube clamped in its fingers to bend your sheet around its radius to create the shape. Ron Fournier's 'Sheet Metal Handbook', page 29 details this process clearly. I've used this method on occasion to great effect.
If you prefer to roll larger radii, (repeatedly and accurately) like the one shown in the trick tools video, then you will definitely need to make a machine dedicated to this purpose. I don't think is a particularly difficult build either. For the adjusters on the two rolls, you could consider using off the shelf self-aligning flange units like the one I've referenced as these provide both the bearing and the sliding adjustment in one ready made, inexpensive part - although the inner bending roll won't need to rotate during the bend.
Anyways, I'm sure you'll get plenty of creative solutions to consider from other users here, but this hopefully gets the thinking process started on your way to creating beuatiful parts...
Manny
Old 02-07-2022, 10:34 AM
Manny, I've used the brake for smaller radius parts. I'm looking to do a full belly pan for a Track T. So that's why I need a bigger radius bend. I plan on making the radius that I need first and others as I need them. That way if I never need them I can make them, and spread the build cost over time. Do you have a link or info where to look for the part you have listed? I 'll try to find info, but if I can't could you send the info. Thanks for your reply. Steve
Old 02-07-2022, 12:19 PM
norson norson is offline
This is the way I did it.
Norm Henderson
Old 02-07-2022, 10:52 PM
pato1 pato1 is offline
how far apart were the two large rings and what gage metal?? thanks-that is great!!!--pat
Pat
Old 02-08-2022, 03:20 AM
Steve, that is called a take up bearing. You'll get them at any decent bearing supplier. They come in a staggering array of sizes (metric and imperial) and as previously mentioned, are self-aligning due to the spherical bearing insert. Attached pic will show how they are set up.
Manny
Old 02-08-2022, 07:55 AM
Default Bearing
Thank you Sir. That gives me another thing to check out, they look like that will solve the problem of up and down adjustments
Old 02-08-2022, 02:33 PM
In that picture the rings are 3 feet?? apart. The table is 4 feet wide. I used the rings because that was what I had to get the bend I wanted and steel because that what I had. You could use that heavy fiber glass. sewer pipe or even the power pole on the corner. You just need to figure out how to apply even pressure across the length of the piece your'e bending (2x4?). Maybe ratchet straps to help. The material in the picture was 18 gauge crs and I was making the cab corner for a Willys pickup.
Norm Henderson
