  #71
Old 01-11-2021, 07:37 AM
metaldahlberg88 metaldahlberg88 is offline
Originally Posted by SATAUS View Post
Hi Tommy
I'm not sure what they are called panel clamps maybe.
Not my idea I just copied them from something I saw.
They are good if you don't mind having a gap in your panels
but I like to have zero gap when I weld 2 panels together
so I use these skin pins with a small plate on one or both sides.
Panel clamps
Skin pins with small plates
Hope that helps.
Awesome! Very helpful. Thanks for the info, Scott.
- Tom D
Old 01-18-2021, 05:51 PM
SATAUS SATAUS is offline
Default Drivers side door top jig saw puzzle and lots of holes to fill in.
Working out were to cut door frame off.
Time to fill some of the holes in.
I had to make a part to fill in the 60mm gap in the door top.
Profile gauge from aluminium sheet.
Top tooling to form part.
Bottom tool.
Practice part only about 20mm long.
Folded edge to guide sheet through form tool.
1st pass through form tool.
About the 5th pass.
Folding the outside edge up by hand.
Finished part not trimmed to length yet.
Part welded in.
Lots of cuts had to be made to match the top of the door frame to the bottom of the door after taking 114 mm out.
Filling the outside gap in and welding the frame together.
Top completed.
Time to get rid of the pesky holes from some one putting a truck mirror on.
Last 2 holes
Finished for now onto the passengers side.
Scott
Old 01-18-2021, 07:44 PM
metalmarks metalmarks is offline
MetalShaper of the Month October 2020
I'm enjoying this...You are at one with the metal!
Chris
Old 01-18-2021, 07:52 PM
Very nice.
Old 01-19-2021, 04:24 AM
Nice attention to detail there.
Old 01-19-2021, 07:43 AM
What did you use those forming dies in? Was it a press?
- Tom D
Old 01-19-2021, 04:14 PM
Thanks Marcus
Scott
Old 01-19-2021, 04:16 PM
Yeah just a hydraulic press.
Scott
Old 01-19-2021, 04:17 PM
Very nice.
Thanks Pugsy.
Scott
Old 01-20-2021, 04:17 AM
Wow, that makes it even more impressive! I thought you were using a Pullmax or similar.
