  #951
Old 05-08-2019, 09:28 AM
pplace's Avatar
pplace pplace is offline
First picture is my favourite and hoping I or someone finds a stock colour close to it to at least start from.
Look into A 1996 Chrysler color with the code L55, name of Spanish Olive.
I have paint samples of that at work and it “may” be in the tone you are after?
Dane
Old 05-11-2019, 10:34 AM
pplace's Avatar
I know pictures in general don't translate true colors properly, and add computer screen color settings, etc. and it's a crap shoot.......but here are some pictures I took out in the sun of that color I mentioned above.
As you can see it has what we call quite a bit of "flop" to it. The face of the color in the sun is much different than the side tone. It goes from a goldish green color to a darker olive color depending on your viewing angle and sun.
Dane
Old 05-12-2019, 05:13 AM
Many thanks for the colour suggestions.
Closest stock colour to the preferred first photo I have been shown so far is Verdoro green as shown on this Holden HT 1969 Monaro. Was used on other GM cars like the Firebird in the same era. Hoping to avoid too much flop. Did they have mica paint back then or this a fine metallic?
Not a lot to show this week as was researching parts for the project coming up, and that can take some time!
A bit of CAD work to get a template for the lower grille reinforcement panel.
I put a step around the edge so it sits flush with the grille flange underneath and sits down from the top. Having the main part lower means I could put a drain in the panel that didn't need to go through the grille flange as well.
Even though I stretched the bead area first on the English Wheel, it is still bowing down in the middle. This tells me the top of the bead needs more stretch to level it.
So I made up this T bar from some rusty bar that fitted the bead. Hammered down into the hollow of the bead directly over the table. Lots of little hits working back and forth and it straightened right up.
Might work well as a post bead stretch even if you have not wheeled it first. Certainly will improve it. I had also rounded the ends of the beads as usual with some pipe with half of it notched out of the end.
I was worried the beads were a little bold but they match the ones in the doors and went with that. Once behind the grille they don't look too bad.
This can now be spot welded in place. Will just add some sealer over the gal coat beforehand around the edges to keep water out.
The panel will get painted satin black and not body colour so should blend in better. Never been a fan of seeing body colour behind grilles.
Old 05-12-2019, 11:33 AM
peter d peter d is offline
Default Paint
Hi all the verdoo green monaros I have seen had more green then the one you posted have never seen one that colour. I used to have a hx monaro came in a colour I think called antelope which is cross between bronze and silver to my untrained eye sorry not clever enough to post a pic might be worth a search .
Old 05-12-2019, 06:30 PM
onya onya is offline
Thanks for the Bead stretching Tip Marcus, I was just having the same problem with some beads even after EWheel.
Leigh,
Old 05-12-2019, 10:28 PM
I do not remember color flip even in the early 70s , only fine metalics from GM then. As best I can remember .Your paint supplier could tone that down a bit if need be. Then give you added color(s) so you could repair later on .
Don
Don Papenburg
Old 05-13-2019, 04:16 AM
From 67-70 there were 3 different types of the Verdoro green according to this post. Unfortunately the test pictures are gone but still tells you the differences.
The HT and HG had different versions too I have been told.
https://www.gtoforum.com/.../verdoro...ifferences.../
Old 05-13-2019, 04:20 AM
A little video update too.
Old 05-13-2019, 04:29 AM
kiwi john kiwi john is offline
Beautiful work as always Marcus, I love your attention to detail. Thanks for sharing with us. Will you be coming to Pete’s on Saturday? Would be good to catch up. Cheers jl
Insanity is defined as continuing the same activities while expecting different results
Old 05-17-2019, 05:08 AM
Many thanks John.
I'll see if it works out that I can drop in tomorrow.
