  #901
Old 04-07-2019, 07:10 AM
Robbo303 Robbo303 is offline
Great thread you do very nice work, meticulous and well thought out.
Rob
Old 04-07-2019, 02:56 PM
Onorius Onorius is offline
MetalShaper of the Month Dec. 2018
Absolutly fantastic work with the hood. And thanks for explain step by step
Onorius
Old 04-07-2019, 07:23 PM
Great stuff, man. You definitely keep setting an ever higher benchmark to which many of us aspire.... As always, thank you for posting.
Old 04-08-2019, 05:38 AM
Many thanks for continuing to follow along guys.
Old 04-08-2019, 08:17 AM
galooph galooph is offline
Thank you!
At the weekend I was feeling a bit disheartened after uncovering more rust on one of my trucks, then I got to thinking of all the fantastic work from this thread that you've done by taking it steady, working through all the problems methodically. Made me feel much better, so thanks!
Dan Smith
https://galooph.com/
Old 04-09-2019, 04:03 AM
Originally Posted by galooph View Post
Thank you!
Glad the thread was of help Dan.
Old 04-09-2019, 06:05 AM
Nature takes its material back. Too bad we can't fix people like this. Maybe it would be possibilile, but mentally it wouldn't be enough for this flashing time of world.
Nice work Marcus.
Old 04-09-2019, 09:21 AM
Job well done Marcus
Old 04-11-2019, 04:39 AM
Nice work Marcus.
Thanks mate.
Thank you for looking in Peter.
Old 04-20-2019, 06:26 AM
Needed to make a template of the bonnet profile where the back flange on the front support sits. I used a trick where you choose a washer that is slightly more that the biggest gap from its edge to the bottom of the hole . Then run the washer along with the pencil inside it to get your line.
As I had to start with a large washer, you can see it is not accurate on the tighter radius in the middle. So I just ran a much smaller washer after this right along the bottom edge to get it right.
I went hunting at the wreckers and found this neat latch and safety catch in one off a 240 Volvo. I cut out the support pieces as well in case I need them. They are very similar to universal ones you can get, but found the quality higher on these. Not sure if it is worth the cost of replating though.
Started with the centre section and decided to put a joggle in so it sits flat with the bonnet skin flange. I also put a dimpled hole in so I can access the stud for the bonnet ornament.
The factory support was not very stiff and the cause of the flutter these bonnets get at speed. That is why I believe you see so many with side latches added later. So I made it flat right across the centre to give greater depth in the flange. Also followed the profile of the bonnet to give more depth in the corners of the steps, rather than just cutting through at a 45 degree angle as the factory did. Also welded in pieces into the bonnet flange to make them the same width in the steps as they were cut right back to aid the pressing of the bonnet. But this also made it weaker in the corners.
I added the same sized dimpled holes as the rear support to tie in the theme. They are much smaller and stronger than the large cut outs of the original support as I don't need access for a spot welder. I will be doing plug welds instead in the holes left from drilling out the spot welds.
The latch will mount in the section in front of the dimpled holes.
The centre section came from a 1952 Willys Wagon that I got along with my 1958 Willys. The 58 and Wagon pieces were actually parts left from building another Willys Truck! I bought all the leftovers. The Wagon has a different hood ornament that is bigger and goes down the centre rib. I designed the front support so that the rear flange ended up right under the mounting hole to further strengthen the skin to the support structure.
This is with the Wagon ornament in place. It used to cover the whole front of the centre section to the edge of the dog leg on each side.
This is one of the original Truck ornaments I have which are shorter and only have two points.
I like the Wagon one better as it helps the proportions as it finishes short about what the original Truck ones did.
