Old 12-03-2022, 04:22 PM
rockable rockable is offline
Default How to make curved panels with stepped inner panels
Occasionally, I see some panels like the one in this truck and wonder how it was made. My guess is you roll the panel, form it and then put the stepped inner designs in. Can someone enlighten me a little on this process?
Rock. Able
Old 12-03-2022, 05:29 PM
It will be a similar process to my two threads. It is essential to no give hard blows so that the material can be processed until the end of the process. Stainless steel is very sensitive to hard blows.
https://www.allmetalshaping.com/showthread.php?t=19618
https://www.allmetalshaping.com/showthread.php?t=20435
With steel you can use heat after shaping the profile for last bend according the car.
A week ago I made 10 identical bumpers from 3mm stainless steel.
Each bumper was individually shaped. Deviations are minimal.
Old 12-03-2022, 07:00 PM
Thanks but that is not what I was talking about. I am interested is how they made the panel in front of the radiator. Maybe I didn't describe it properly. It is a bead rolling operation.
Rock. Able
Old 12-03-2022, 11:39 PM
Maybe variations arrive at the same destination.
I see three panels and two weld seams.
Form blocks for the two stepped seams = pattern layout cut fit form fit trim weld planish fit.
Then some roll-bead work.
Gold plating?
Old 12-04-2022, 10:45 AM
heinke's Avatar
heinke heinke is offline
Default One way to form this type panel
When I made this panel which has bead rolled elements on a curved surface, here's the sequence of steps:
So 1) bead roll insets, 2) add bends and curves, 3) weld up into the larger panel.
Joel Heinke
Old 12-04-2022, 11:53 AM
pato1 pato1 is offline
absolute perfection-the whole interior!!--exquisite workmanship...
Pat
Old 12-04-2022, 02:33 PM
Nice interiors are a lot of work.
Planning and experimenting.
Also the headliners in one sheet of metal.
Nice work and good to see it here.
Old 12-05-2022, 07:39 PM
Very nice work, Joel.
So, what it think I learned is, "It depends." Sometimes to make the panel and thn roll the beads and sometime you roll the beads and then roll/curve the panels. Obviously, you can't run them through a slip roll. Thanks.
Rock. Able
Old 12-05-2022, 09:22 PM
Funny thing - cutting chip board/poster board etc. various thickness/density puzzle pieces w/x-acto and st. edge/Fr. curves to make "filler surfaces" fitting depressed areas allows slip rolling of "quilted" flats.
Old 12-06-2022, 04:30 AM
What a fantastic interior!
