Old 11-04-2022, 05:32 AM
Leepac1 Leepac1 is offline
Default Radiator cowl front panel
Hi, I am currently making a replica Le Mans Bentley and would like some advice on how to make the finishing trim panel in-front of the stone guard, as per the photos, thank you in advance, Andrew.
Andrew.
Old 07-15-2023, 12:48 PM
A few photos of the radiator cowl after a few months of metalwork.
Andrew.
Old 07-15-2023, 01:04 PM
The finished item on the chassis with the newly plated lights to match.
Andrew.
Old 07-15-2023, 06:01 PM
That turned out really nice!
ærugo nunquam dormit
Old 07-16-2023, 01:59 AM
Cheers Steve, thank you very much, I am quite pleased with it.
Andrew.
Old 07-16-2023, 03:01 AM
Andrew, this is top notch work.
I can see from the date that no one advised you. You didn't need it. But could you describe the process.
To widen the vision.....
Old 07-16-2023, 05:10 AM
Well done mate, that came out great!
Old 07-16-2023, 08:20 AM
Marc Bourget Marc Bourget is online now
I'm interested in how the cap seals and why the switch from the original over-center lever operated closing to the Winged version which I assume is a screw-on method?
I've seen aircraft filler caps that employ a flexible seal that is squeezed out when compressed but the inlet material appears too thin for that approach.
Marc
Old 07-18-2023, 01:00 PM
Hi Jeroslav,
The way that I eventually made the "z" shaped trim/stone guard retainer was to make each half in 3 parts. The two corner sections were made using an aluminum hammer form that I fabricated out of a 17mm piece of solid plate cut on an angle using my bandsaw. When the "jig" was made, the corners, both being the same, were quite easy to fabricate and the join onto the 2 upright and vertical sections, the completed trim section was then soldered onto the main radiator shell once manicured to fit snugly.
Andrew.
Old 07-18-2023, 01:04 PM
Hi Marc,
I have used an aftermarket aluminum radiator that is fitted under the new shell, it uses a modern day pressurised rad cap, the Bentley flying "B" is just there for embellishment as the radiator is filled from under the bonnet.
Andrew.
