Go Back   All MetalShaping > Miscellaneous stuff you need to know > Comments and Suggestions
Old 06-21-2023, 10:35 AM
Kent, will those work for "flow forming" or do they his too light?
For smaller tubing, I've seen a variety of vibration sources work well,
from a de-magnetizer, vibratory bowl and an air compressor.
Now that I think of it, maybe a rivet gun adapted for the purpose.
Old 06-21-2023, 10:46 AM
DavidB DavidB is offline
For some smaller tubing sizes, 8mm 10mm 12mm sort of bore, I've used close fitting nylon rod greased or oiled so that after bending it can be removed relatively easily often with some twisting.
David Billington
