Old 10-27-2021, 01:54 PM
Default What's between wood and steel?
I am just trying to rebuild a steel and wooden car. Originally, some spacer fabric was inserted between the wooden skeleton and the car frame. Like a pad for leveling unevenness. What is put between the wood and the frame today to keep it working for another (hundred) years?
Witold
Old 10-28-2021, 07:47 AM
Default Thermal expansion.
Fabric, usually canvas, is there to allow the wood/metal to slide separately . All material expands/shrinks at a different rate. To be scientific. The amount of expansion/shrink is calculated by the expansion rate of the material times the temperature difference times the length of material. For replacement material look for something that does not absorb water. You do not want to rot the wood nor rust the metal.
Old 10-28-2021, 02:01 PM
Witold. That's what I'm interested in. I'm just tiling the car and we don't put anything between wood and sheet metal. It is lined with aluminum sheet. I did not observe the substance in other cars. I need to look more closely.
The one who advised me said that the sheet metal must be placed exactly on the wood. There was no talk of fabric.
Old 10-29-2021, 10:01 AM
I have a reprint of an old Fisher body manual some place around here . However I do not recall having seen anything about placing something between the wood and the steel . my 29 Chevy truck was just steel on wood . the 33 Pontiac does not have anything either . It might just be the hand made customs and high end very expensive cars of the day that had a little something extra.
Don Papenburg
Old 10-29-2021, 01:00 PM
I was told by craftsmen older than me that the fabric was used to stop squeaking, when the wood and metal rubbed together.
What I have seen was a woven heavy cloth about 1/16 thick. I have also seen it soaked or impregnated with tar or cosmolean type material.
If memory serves me Model A Ford used on frame below wood body mount blocks. Also between wood and metal in roof area. A hupmobile I worked on a number of years ago used it in a similar manner. Current project a 1953 EMW also has the cloth used as well.
Old 10-29-2021, 02:36 PM
I've only seen this on coachbuilt auto bodies - not the production cars - even the Caddy V16, Packard 12, Lincoln 12 had none- unless coachbuilt.
Bugatti used a thin fabric - we used linen because it was a period type of fabric, weave and weight. Also as carpet underlayment, first of two under carpet. (Carrosserie Bugatti - not Gangloff.)
Touring primed the steel frames with some sort of brush-on orange primer then laid on the cotton fabric over the tubing and under the aluminum skins - we used linen as we had rolls of it.
They also used burlap that was pushed into interior gaps in trunk area and was then brushed with hot tar.
Sindelfingen had fabric under floorboards and between wood and floor pans to reduce leakage.
Graber used fabric under floorboards and around floor pans to limit leaks. We used linen after all painting done and pans were being installed into floor areas. Nice, clean and tidy.
Other than that, I have no idea.
-end-
Old 10-30-2021, 12:26 PM
-end-
Further, on the production cars I am familiar with (1910 - 1941, various US mfg), an anti-squeak anti-chafe heavy woven and frame-wide tar-embedded fabric was laid onto the steel (or wooden - Franklins) chassis frames and the bodies set on top of that. Spacers of tire tread, square cut and center punched were commonly also used where the body hold-down bolts came through. These were arranged/stacked also to shim the body correctly for its proper mounting geometry, to absorb the little variations in production.
-end-
Old 10-30-2021, 01:27 PM
dwmh dwmh is offline
Gosh, Kent I wish I had your level of 'no idea' on this and many more subjects.
Good man.
David Hamer
Old 10-30-2021, 02:03 PM
You are right that the distances were used in exclusive cars. In the second photo, the remains of the original material taken from the car. It was used as spacers in places where the wood was screwed to the frame and along the entire frame (one layer). My question: what to apply today? Can you buy something similar?
Witold
Old 10-30-2021, 03:15 PM
Originally Posted by Brzeczyszczykiewicz View Post
Attachment 61605
Attachment 61606
In Oka City -
https://classicautoparts.com/anti-squeak-pad
