Old 02-26-2021, 11:02 PM
norson norson is offline
What about the fixture table clamps that rely on side pressure? Drilling holes is an overpowering job.
Norm Henderson
Old 03-02-2021, 07:19 PM
Default holes
My welding table has plain holes (5/8"), no threads. It is easier to keep a straight hole free from spatter than a threaded hole. There are commercial straight shank clamps available. I just weld a stub on a cheap wood clamp. The offset makes the peg wedge in the hole. I also made some shouldered pegs for squaring. 5/8" socket head bolt works too.
Bill Funk
Old 03-02-2021, 10:23 PM
Man, that's a lot of holes and my table is 3/4 inch thick and 4X8. I'm thinking I would want to start out more conservatively. Thanks for the response, by the way, I like the clamps you built.
Norm Henderson
Old 03-03-2021, 09:12 AM
sfm1951 sfm1951 is offline
That is a lot of holes. Thinking about marking out the grid and drilling every other hole and drill others as needed. And maybe not tap the holes as I can get to the holes on the bottom. I might tap them later if and when I get a tapping attachment. Read that as when I win the lottery . Lol but somebody has to win right?
never-ever kick a fresh turd on a hot day!
Old 03-04-2021, 06:10 AM
Default Weld table
Full disclosure, I did not drill the holes. The table is a kit of laser cut parts. The laser cut holes actually work better than drilled hole. They grab the straight shanks better.
I got mine here, because it is 30 miles away and I saved on shipping. But any laser shop should be able to make a table. Depending on how you buy your steel, it may not cost much more, as they buy bulk and get a discount.
https://weldtables.com/products/copy...ab-slot-u-weld
Bill Funk
