Old 05-18-2022, 11:27 AM
jcarpenter jcarpenter is offline
Default Thread on reverses
Mark, Thanks for the link. Especially interested in your pictures of plastic dies for the TM air powered hammer. Got one of those and starting to play with making a hotdog die. Hasn't worked out well yet but my lower die had no shape.
Doing reverses on anticlastic pockets by hand seems to work better for me at least for now. Your art is an inspiration to me when things are being difficult.
Thanks,
John C
Old 05-18-2022, 09:26 PM
Attachment 63519
Thanks,
Hi John,
About your image of the curved hotdog, a hint to drill down into the 'dog w/dia. and blind depth enough to press in your hammer die "stump" - then weld - if not already done.
Old 05-19-2022, 07:25 AM
mark g mark g is offline
Hose clamps are handy for pulling edges of the form closed.
Mark
www.markgoodenough.com
Old 05-20-2022, 07:39 PM
I don't actually use a stump. I use an arbor press and Baltic birch with a spherical cavity carved into it. On of my problems has been the 1.5 inch square arbor shaft that gets in the way when I try to do a long shape that turns into a spiral. So new tooling for the press. A tooling hole was drilled into the end of the arbor shaft and a grub screw added. The tooling is a 3/4 inch ball bearing welded to a 9 inch long 1/2 inch diameter shaft.
Used the press to stretch the bottom of the metal into the cavity and crush the tucks that formed along the edges. Ended up with a nice long bowl wrapped into a spiral. When the edges are folded over it will become the tubular octopus arms. The long narrow tooling works much better than the old shaft.
John C
Old 05-21-2022, 11:20 AM
cylinder9 cylinder9 is offline
Very cool project.
Dan
Old 05-26-2022, 01:00 PM
Default Maybe I need a different appraoch.
Got the spiral shrunk about where I wanted it. And it was getting harder to shrink all the time.
Then proceeded to close the edges onto themselves to form the tube. Join of the edges is not welded yet. I liked the result. Quality not there but the shape is what I want. However.....
Too much physical effort went into this arm. The multi-turn coil is too clumsy to work with and any change along the coil effects other parts of the coil in ways I can't yet predict. I think I will try a one turn only coil and when I need more I will just weld additional tubing on.
John C
Old 05-26-2022, 02:09 PM
fciron fciron is offline
Those are looking great. That is a very lively looking tentacle.
Remember, actual octopus tentacles aren’t round, they’re more semi-cylindrical, with stickers on the bottom. That might make things easier to manipulate.
Lewis Meyer
Falls City Ironworks
Louisville, KY
