Old 04-03-2021, 07:59 AM
jcarpenter jcarpenter is offline
Default Newbie built buck
Newbie trying to learn metalshaping. Tried to fabricate metal fish but don't have the skill set for that .....yet. No project car and no room for it so thought to try a scaled model of a car. Something simple and organic. This is my effort to build a scaled model buck of a sprint car to use to learn metalshaping skills As much computer and CNC as possible used as I have that skill set and tools.
This is the sprint car model I wanted to make into a buck
I use the 3D modeling program Blender 2.8. It is powerful and free. The sprint pictures were cut up into front, back, side and top views and placed, scaled, and aligned in the Blender program.
The model was formed around the pictures. This is a simple block modeling approach as I am still learning the software. Once the model was good enough to use it was exported as an STL file to Fusion 360 Slicer.
F360 Slicer is a free stand alone Buck design program that can be integrated with Fusion 360. There are endless choices in F360 Slicer but if you keep it simple a decent output can be obtained. Fusion 360 is not required
Once the buck model looks ok in Fusion 360 Slicer, DXF images of the buck patterns are produced and saved for use in VCarve Pro, a CAM program for CNC routers.
The dxf buck files are used by VCarve PRO (definitely not free) to nest the patterns and generate tool paths for the CNC router.
The frames are cut out on a 4x8 cnc router
After a bit of trial and error the cut frames are a really good fit and slide together.
Scale model buck and some nose and tail end pieces for off buck shaping. Some tweaking and fairing needs to be done. So far it is cheaper than a project car.
Now to try and fit some metal to the shape!
John C
Old 04-03-2021, 09:04 AM
dwmh dwmh is offline
You have made a great start. It should keep you out of mischief for a while.
David Hamer
Old 04-03-2021, 10:18 AM
That is a pretty good approach to building a car ,I am sure it can be done with any basic car drawing , Good job .
James
Old 04-03-2021, 11:59 AM
Thanks dwmh and James. I already know from doing the fairing and playing with some paper patterns that there are too many large flat spots and the body needs to be more of a round tube than a rounded corner rectangle. I'll make another one after I have played with this one for a while.
John C
Old 04-03-2021, 05:36 PM
John, that is a really nice start. Your result will be better having a buck to align to as you shape the subpanels.
CHeck your Private Messages.
Old 04-05-2021, 05:14 AM
So great how it can be done now a days.
