Old 05-09-2021, 12:07 AM
Johnny Bravo Johnny Bravo is offline
Default Help from iPad or iPhone users
How do you guys stop the dreaded rotation of photos when you post from an iPhone or IPad? Itís got to do with how an iPad stores a photo. It rotates randomly when you resize as an attachment. Problem is it always displays correct on my iPad so you cannot see which way itís rotated until you post it on the forum. I used to have the same issue on four other forums,but they have all since sorted the issue out. Comments like hold the phone in a different orientation when you take a photo isnít a solution
So, how do you guys do it?
Johnny
Old 05-09-2021, 03:37 AM
Two40ís Two40ís is offline
I have the same issue on other forums and solved it by taking all my pictures with the home button on the right, Iphone in horizontal position. This solves my issue but if I take a picture in a different orientation it rotates the picture when posted.
Michael
Old 05-09-2021, 03:43 AM
Repost����
Michael
Old 05-09-2021, 04:03 AM
MetalShaper of the Month April 2020, September 2021
If you open the image and save it again in the correct position, the problem will disappear. I hope it's the same with the Iphone.
Old 05-09-2021, 06:42 AM
BSG BSG is offline
Nope, doesn’t work with iPhone…….the volume buttons need to be down and the home button to the right.
There’s photo editing software that supposed to work, have no idea what one or cost?
Kevin.
Old 05-11-2021, 02:57 PM
galooph galooph is offline
Hi Johnny,
I've been testing a fix on our testforum, which seems to sort the image rotation issue. I've moved the fix onto here, so if you could test uploading some images, that'd be great.
Thanks,
Dan
Dan Smith
https://galooph.com/
Old 05-11-2021, 03:07 PM
I put pictures through the computer. I'll save them to a folder first. I edit and then present them. That's not the problem. With unedited images can be.
Another problem occurs if you lose your mobile .....
