#1731
Congrats on your initial fire up!!! It's confirmation of your meticulous work. Well done.
I'm hoping for the same results soon.
#1732
G'day Marcus,
I hope your first Fire Up was at 3.00Am like all good Hot Rodders do. Onya Mate.
Leigh, Stop moving so fast, you're creating a breeze. |
#1733
That was a beautiful moment.
"The punishment for desire is the agony of unfulfillment." |
#1734
I did that in '65. It was a 365 hp 327 with open headers in my '55 Chev. My neighbor contacted me the next morning and said "Normy, honey, could you try to do things like that before midnight in the future". Her bedroom window was ten feet from the blast. God, that lady was a saint.
Norm Henderson |
#1735
Fantastic! I absolutely love this project! The look on your face was priceless! Now that is pure joy! It runs flawlessly after it warmed up, Congrats!
Dave Iggulden Instagram: https://www.instagram.com/magnamachineworks/ Youtube: https://www.youtube.com/channel/UCiE...JpkNiOeGgxY45g |
#1736
What a wonderful milestone! Thanks for sharing, Marcus, it was a delight to see your joyous reaction!
#1737
Wow, thank you so much guys for sharing in the milestone. I was truly delighted that it started.
#1738
Thanks guys.
![]() Ran a very high concentrate of fuel injector cleaner through it today and now it purrs and no check engine light! ![]() I let it idle for 20 minutes or so and the temp started to climb. The hydraulic fan was barely moving so was worried but knew there would be air in the system too. Suddenly it ramps up speed and a lot of air came into the reservoir as I moved the steering from lock to lock. All connected to the same system. Noticed water wasn't circulating either with a cold top hose so must be a stuck thermostat. Was about to shut it down as getting nearer the red zone and heard a click and it released itself and temperature plummeted. Tried several more runs and just sits at the correct temp perfectly now and the fan speed varies accordingly to need. Most of the time not needed at all. Very happy it fixed itself. ![]() Only problem I have is when trying to accelerate, while on the jack stand without wheels on, the traction control is kicking in madly and triggering the ABS. Not sure if it is because I still have to bleed the pump using the scan tool or it is getting confused without any wheels on and no road speed?
#1739
It's because it's up on jack stands. I've had that happen before.
- Tom D |
#1740
"The more brains you use, the less materials you need."
I guess that's why I use so much material!
http://pokiespages.com/ |
