Old 01-27-2021, 05:43 AM
Bart Bart is offline
Default Roof Panel fab
Hi Guys
Just wondering what some have used or prefer to shrink the edges of a roof skin panel, or any large panel you've worked on. Trunk, hood.
So far I've been able to shrink the edges to a reasonable level and got pretty good curve in the panel, but wondering if anyone has better faster ways? Please post pics, I think because its quite a large panel (roof panel) there's a lot of material to shrink and its going slower than I like.
It's a low crown roof, I'll be doing some wheeling on it soon.
Thanks everyone
Bart Risuccia
Old 01-30-2021, 07:22 PM
Reno Reno is online now
Bart, I am going to have to shape a low crown roof panel to fill the roof opening in the Austin. I like Lazze's explanation with multiple soft rectangles with diagonal passes through the English wheel.
Eugene
Old 01-30-2021, 07:37 PM
Cool, i was thinking diagonal. I haven't gone too far with it so ill ill try it.
Bart Risuccia
Old 01-31-2021, 02:08 AM
Bart. We used a back bend on the edge of the panel. The back bend holds the shape. When you have finished shaping the panel, straighten the edge. The panel holds its shape throughout the shaping in EW.
Old 01-31-2021, 03:16 AM
Interesting, I've never used that before
Bart Risuccia
Old 01-31-2021, 05:35 AM
Yes, that is the edge about 40 - 50mm. This edge holds the entire panel. After shaping, you can straighten or cut it. The shape of the panel does not change.
Try and send a photo. It's simple to unbelievable. A friend advised me with in shape the rear hood. He laughed at me as I could not produce it. The shape bent more than I wanted. It rippled in all directions. Such a simple thing solved it. We bent it in straight wheels in EW - without measuring - on the eye.
Again, the devil is hiding in the detail.
The customer did not know that the hood was made this way. He thought that the hood was supplied by someone made by pressing or that it was original. A little secret ..... Expensive car.
Old 01-31-2021, 08:18 AM
So did you make the edge first?
Then start shaping?
Bart Risuccia
Old 01-31-2021, 10:10 AM
(Bart : note also - for tough metals like 2024 T3, stainless, Ti etc, or on thick sections, we make angle pcs and rivet them on in the outer trim zone, so they help hold shape during shaping)
Old 01-31-2021, 10:32 AM
I would shape a little and then lift it. It starts to twist badly quite soon. It still looks like it's not shaped yet - the panel looks turned in all directions. Then you find out it's more arched than you wanted. And you can't use so many garden grills that you didn't want to make.
The edge holds it beautifully. You have to try. No stress.
Old 02-01-2021, 02:46 AM
Thanks guys.
Ill post some pics soon
Bart Risuccia
