#1681
Steve, I'm showing 168 pages
#1682
I have 84 pages.
#1683
That's odd.
#1684
Nah, it's in user preferences, how many posts one wants to see per page.
I now know you're seeing double the pages as I am, so I went back to page 38 and found the glass info. |
#1685
![]() Quote:
#1686
I masked off thearea around the windshield to prevent getting any of the windshield adhesive on the dash or frame. It's difficult to remove if it gets on anything it's not supposed to be on.
I use DuPont Betaseal U-418 on windshields. It's a fast cure version of the U-428. This is what most OEMs use and it costs less than half of what 3M Window Weld costs. Dave to the rescue again. I had my buddy stop by and help me set the windshield. They aren't that heavy but they're big and have to be set in accurately to avoid smearing the bead of urethane. It laid down perfectly. Perfect fit. I was surprised at how accurate I made the frame considering I was in the rough-in stage when I built it. I do remember spending a lot of time getting the windshield frame as accurate as possible when I was getting everything roughed in, but I had to guesstimate some things in the process. I went around the perimeter with a flash light to check for full seal and found an area about 2 inches wide along the top edge that didn't seat. I gradually slid the windshield side to side while applying pressure to the front face and managed to reduce that gap to less than one inch. I'll let it cure like that and fill that gap tomorrow. The glass needs to be installed in its relaxed state. You shouldn't squeeze and clamp till the adhesive dries to seal a problem like this. The pressure built in will eventually crack the glass. I'll put the reveal moldings on after I seal up this spot.
#1687
Thank you for the information Jack.
#1688
Thank you for the explanation. I know understand the black perimeter on our newer cars!
Larry |
#1689
I resealed the top edge of the windshield and checked for leaks; high and dry. I put on the upper and lower reveal moldings and everything fit right after a little trimming on the lower molding... Windshield is done. Most people will never believe what it took to put a 58 Buick wrap around windshield in a 49 Cadillac.
Jack Set a Goal So Big That You Can't Achieve It Until You Grow Into The Person That Can. Last edited by Jack 1957; 01-26-2021 at 12:05 AM. |
#1690
Wow, that looks terrific Jack!
