Old 09-02-2021, 09:13 PM
If all of the above do not cure the zaps pull the face off the electric panel . A loose wire on one or all of the hots and or ground will make you light up.
Don Papenburg
Old 09-09-2021, 05:14 PM
Harpkatt Harpkatt is offline
I will be back to my shop this weekend finally, I will report back with my solution.
Chris From Long Island
Old 09-12-2021, 12:46 PM
Hotflint Hotflint is offline
I also have the Lincoln Square wave 200. I really like it. I am glad I found this thread, I will definitely be following
Old 09-12-2021, 09:01 PM
After following everyone's advise to check connections, grounds and terminations. I found the issue after I pulled the case apart...The amptroller connection turned out to be the issue. The big label that says "make sure this connection is tight" should've been a good tip. That said, I did start running a dehumidifier in my shop since its eternally damp in there. So while damp gloves may have been a contributing factor before I'll never know. That said, it works. I'm zap free and that's as much as I can ask for.
Thanks for the help.
Old 09-13-2021, 10:11 AM
boltboy49 boltboy49 is offline
MetalShaper of the Month February 2024
I'm glad you got the issue resolved. And the dehumidifier sounds like it will make things more comfortable.
AL
