  #51
Old 05-29-2021, 06:39 AM
Ok, work carefully, the arc cannot be returned even if it is small !!!!!!
Old 05-31-2021, 07:53 AM
Bart Bart is offline
currently making a simple table to hold the sheet while i EW
Bart Risuccia
Old 06-13-2021, 03:39 AM
Just a question on how much excess material to leave as I obviously don't want to cut or trim too much.
So the red line is where I want to cut, the green line is the end of the panel which is about 70mm away. Orange line is a shallow fold or crease.
I figured trimming what I don't need now would make it a little easier to move the panel around for E wheel and other work.
Bart Risuccia
Old 06-13-2021, 03:55 AM
Bart. Compare my picture to yours.
Why do you think I have a bent edge upside down? I have it bent upside down to keep it in shape. What does it mean ? This means that the product does not twist differently than you want.
If you have an edge bent in the same direction where you shape, you have it bent unnecessarily. You just worry unnecessarily and don't take good advice. We were worried too. Then we got this idea and it was solved.
When the shape you really wanted appears on the plate and that means in all places, only then can you cut.
Compare both photos and write what you see. Make an experiment on a 1 x 1 meter plate and you will immediately understand what I meant.
Ufff.....
Old 06-13-2021, 04:26 AM
Yes i have bent the edges, it looks a little flatter now because there's a curve in the sheet steel.
I thought maybe at this stage to cut off what I don't need and bend up again along the green line as i need to E W a little more
Bart Risuccia
Old 06-13-2021, 04:39 AM
I put arrows on where its bent.
Bart Risuccia
Old 06-13-2021, 06:29 AM
Bart. When your shape is done, cut. But if you are not in the right shape, uncontrolled waves will occur again.
Think about future steps well. Good luck.
On the first try, you embarked on a work that few people can do.
Old 06-13-2021, 06:30 AM
No worries
Thank you, i wont cut.
I should have practiced on smaller piece but i guess typical of me to start big
I hope to be successful, if not i will learn
Bart Risuccia
Old 06-19-2021, 10:46 PM
Happy to say its getting closer front to back. But left to right sides need more EW.
Slow progress but its good so far.
Bart Risuccia
Old 06-20-2021, 07:41 AM
Bit more EW tonight.
I think its enough for tonight.
Bart Risuccia
