Old 12-03-2021, 03:48 PM
AutoPilot AutoPilot is offline
Default Seeking assistance on method to replicate this part
I made the dome shown in these pictures several years ago when I had access to a beater bag, mallets and an english wheel. It's been sitting in my garage ever since and is a little rough! Material is aluminum, but I can't recall how thick. I'd like to replicate something similar in both aluminum and sheet metal, probably 18 guage. Most likely, I will make them in several sizes and will need some smaller radius domes. I don't have access to either a pnumatic planishing hammer or an english wheel. This is the question.... Could this be accomplished with either an english wheel or planishing hammer? Which would be the best choice? I will need to buy or make the tool and the hammer appears easier and cheaper than the english wheel. I am not looking for a super smooth finish for a car body or anything of the sort. This is for part of an outdoor sculpture.
Thanks in advance for all replies.
Jim
Jim C
Old 12-03-2021, 05:38 PM
I think you could shape it with a hammer on a steel plate or a sandbag. You can fill your wife's purse and return it when you're done - she won't even notice .... Bird feeding can be used instead of sand. Millet.
Old 12-03-2021, 06:02 PM
I was not aware that Millet was an option. I’m concerned about my ability to achieve acceptable smoothness by hammer alone, however.
Jim C
Old 12-03-2021, 07:18 PM
blue62 blue62 is offline
You can shape that up with a blocking hammer on a sand bag. That step would only take a few minutes.
Then planish smooth with a planishing hammer and slapper on a bench-head. You can make it as smooth as you want it by planishing. just takes time and patience.
If your a novice metal shaper it would be a good exercise to learn a little about how metal reacts to the thing you do to it.
Blocking on a sandbag is a primary step in making most panels.
Dave Bradbury
Old 12-03-2021, 07:54 PM
Absolutely agree.
(Set your bench head height to your best arm swing - so bh striking surface height = your elbow height minus hammer face/handle length = arm parallel/floor at strike.)
Relaxed work. Hammer/slapper weight+drop = force needed.
Relaxed working. Not "throwing" the hammer against the metal via shoulder .... (as in maul-splitting firewood??)
Old 12-08-2021, 07:49 PM
fciron fciron is offline
A hardwood stump is a nice tool as well. Even a slight hollow will allow you to sink the shape quite easily and you can smooth it out by working from the inside on a flat part of the stump.
Alternately, you can make wooden stakes out of hardwood as well. I have an oak 4x4 with a dome sanded on one end that is very useful. It's easier to read the surface from the outside of the dome during the smoothing.
Lewis Meyer
Falls City Ironworks
Louisville, KY
