Old 04-26-2022, 08:21 AM
idickers's Avatar
idickers idickers is offline
Default TIG torch lead question
I am about to upgrade my TIG welder to a water-cooled torch. Is there a need for a 25' length torch lead vs 12' lead?
I have one of the newer inverter machines on a rolling cart. I'll be using this primarily for automotive mild steel sheetmetal and roll cage fabrication in a car, and my aluminum will mostly be accessible to a rolling cart.
Ian in Rochester, NY
M2 site
Old 04-26-2022, 08:39 AM
latoracing latoracing is offline
Really would never need a 25' lead, unless you were having to move around a lot. 12' works great for me.
I use an air cooled torch and have no issues with it getting too awfully hot, even when welding for hours. For lower amps on steel / stainless steel I don't personally see the need for a water cooled torch. Now, if you start welding aluminum often, that is a different story.
I have never made anything, I just modify the things around me into useful items with abilities that were GIVEN to me.
Old 04-26-2022, 08:50 AM
idickers's Avatar
Aluminum it is. Thanks for the suggestions.
M2 site
Old 04-26-2022, 12:31 PM
"Roll cage" welding/fab ....
NHRA used to offer specs.
Was .090" wall thickness for some. ... That might tend to get hot, if sustained. Might plan coffee breaks, accordingly? (just noodling the details.)
Old 04-26-2022, 12:51 PM
idickers's Avatar
Thanks, Kent! It's for road racing, mostly 1.5" x .095 and 1.75 x .120 wall DOM. I may keep migging the stuff while I explore options with TIG.
M2 site
Old 04-26-2022, 04:15 PM
Yep, sounds right.
The MIG ain't so bad - if you use dualshield, spatterstop, a quench bucket for the gun ....
preheat can hep, or warm the shop - had one guy call me from N. MI, January, complaining about "crax" in gas welds/4130 airframe.
Hmmmm: "How cold is it in your shop?"
- "Um, 20F."
"Got a heater on your body?"
"...Yes..."
"Why not get another small radiant heater for the area that you are welding? Move it along with your progress on the frame?"
".... Okay."
That extra bit of temp. stopped his post-weld hardening, as I heard back later.....
But that extra 50F also helps weld smoothness/penetration.
Small things matter.
Old 04-27-2022, 01:22 PM
I’ve always used 25’ leads as the standard 12’ ones you seem to get with new welding sets always seem a bit restrictive. I have a water cooled Kemppi AC/DC set so tend to leave it in the middle of the workshop and move between jobs as required. My workbench is 6’ square so I’d struggle to get round with 12’ leads. That being said, longer leads are more prone to damage and it can be difficult to repair water cooled ones. If you can make do with shorter leads, that’s your best option. If you like flexibility of movement then it’s the longer ones you need. There’s no best choice other than what suits your needs.
Gareth Davies
Old 04-27-2022, 01:23 PM
climb-101 climb-101 is offline
I do a lot of tig work and the longer the lead the nicer it is. the short lead seems like it’s plenty long until you actually get started doing stuff then your always trying to get the machine closer. Also he water cooled torches are the way to go. the torch body is smaller so it’s easer to get into tight places and move around. also get a good leather cover for the leads to protect them and don’t step on them. that was the first thing i was taught about tig welding “don’t step on the leads”.
Seth
Old 04-28-2022, 06:51 AM
Tom Fritz's Avatar
Tom Fritz Tom Fritz is offline
You can not make a short one long but a long one does not need to be fully extended. Go with the 25' with covered hoses and a leather sheath over all 3 hoses.
Tom Fritz
Customs Classics and Rods
www.ccrod.com
Your 49-51 Ford/Mercury woodie expert
Old 04-29-2022, 04:39 AM
Default Tig torch length
I have 25 foot on my old transformer machine. It pretty much just sits at the bench. My portable thermal arc has 12 ft. If the machine is easy to move, 12 is best. 25 ft of cable can be a trip hazard most of the time.
Bill Funk
