  #1801
Old 01-01-2022, 08:27 PM
WordMan's Avatar
WordMan WordMan is offline
A-m-a-z-i-n-g-!-!
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 01-02-2022, 03:10 AM
Originally Posted by WordMan View Post
A-m-a-z-i-n-g-!-!
Many thanks.
Old 01-02-2022, 03:22 AM
Fargoman Fargoman is offline
Looks good Marcus.
Interestingly I've never seen a windscreen roped in from the outside. I've always done it from inside and only ever seen it done that way.
Must be a Victorian thing! Clearly it works.
Old 01-03-2022, 04:24 AM
Good to hear from you mate.
Not sure why Willys designed it to go from the inside. It is what is stock on these the manual shows it too. Everyone has always done them that way and the position of the pinch seam dictates it too.
Old 01-03-2022, 05:14 AM
37 Ford back glass goes in the same way.
I'm sure there are several others like this.
Old 01-03-2022, 09:17 AM
Reno Reno is offline
MetalShaper of the Month May 2020
The 1950 Austin manual shows that for the opera windows, and the same method will apply to the quarter windows in the two door.
Eugene
Old 01-04-2022, 01:47 AM
Learn something mew every day.
I just got 3 days worth!
Old 01-04-2022, 03:00 AM
I think the gasket I bought by the meter is to suit early Ford rear windows as looked the same. I also used the same gasket for the Willys rear window as well.
Old 01-04-2022, 05:27 AM
When you cut it, did you cut the exact window opening perimeter or did you take off 1/2" or so for some stretch?
Old 01-05-2022, 03:37 AM
I cut it long by 3/16"-3/8" as rubber shrinks over time. Also means there is no strain on the join and sits into the corners far better.
