  #851
Old 02-06-2019, 02:45 PM
Detailed updates are one thing, What I appreciate is the detail and planning analysis you went through in approaching a problem - especially problems I lacked the insight and experience to recognize.
You have taught us how to "build" rather than just weld or shape.
Kudos
Marc
Old 02-06-2019, 04:54 PM
Your video is a wonderfully lucid way to explain the task ahead and before then!
Great to have you in action again Marcus,
Cheers Charlie
Old 02-06-2019, 09:40 PM
I've missed your updates Marcus. Sorry for your loss. It's never easy even when you are prepared.
Old 02-07-2019, 06:15 PM
onya onya is offline
Giday Marcus,
Good to see you back at it mate.
Leigh,
Old 02-08-2019, 03:39 AM
Thank you all for the comments.
Old 02-19-2019, 07:25 PM
Just a small update but at least it is an update.
Won't go into much detail on this side stretching the guard length as it just the same as the other side. I did form the centre rib differently using this combination of dies.
Also will extend the cutout over further past the rib using the whole patch as much easier to planish the weld. Also notice the fatigue crack at the tip where it had thinned from rust over time.
I have shrunk the edge before tipping the flange in the bead roller so it keeps the contour.
Will finish the tipping just using a rounded cold chisel as a stake.
A bit of planishing over a shoe last.
Putting in a matching bead on the inner guard to match the stock one that was only on the opposite side. It extended above where my new panel was going so I quickly hammered in the rounded end by hitting up into the piece of water pipe using a small ball peen hammer.
Bead matched in well and the extended front guard is all done for the moment.
New tip piece was all TIG welded into place.
I have always noticed that it looked like the guards splayed outwards towards the front. As in the outside of the guards are not parallel to each other.
Marking the same distance in from the edge front and rear showed I had to push them inwards at the front an inch each side to get them parallel.
When you look along the side now it looks much better. But I don't want to just make the new grille 2" narrower and loose engine bay width. Also the front of the bonnet pieces wont line up if I do it that way. So will narrow the guards along the inner edge instead. I am reworking them later anyway.
Old 02-19-2019, 09:16 PM
blue62 blue62 is offline
I always enjoy your posts.
Nicely done.
I notice in all you posts that your shop is always very clean and organized
that's just not right
Dave Bradbury
Old 02-21-2019, 07:18 PM
AllyBill AllyBill is offline
This is without question my favourite thread in here. What a beautifully executed piece of work but I'm sure I'm not alone in my feelings of inadequacy at how tidy and clean that workshop is.
Here to learn.
William Pointer
Old 02-23-2019, 06:23 AM
Many thanks Dave and Bill.
Old 02-23-2019, 06:25 AM
So this grille I had already added two extra grille slots too making it 130mm/5" wider than stock. But the firewall is 230mm/9" wider so adding the rest between the headlights and the grille.
Tacked on the 50mm/2" wider strip for a look, but looks rather 'tacked' on rather than a factory look and a bit unbalanced between the headlight and the grille.
Then I thought maybe adding a bead the same width as the ones in the doors might help. It will end up in the middle between the edge of the headlight trim and the side of the grille.
The ends of the beads were quite distorted so the rusty bit of 3/4" water pipe fixed it. Lined up the ends of the pipe up with the mark where I stopped the beads and gave it a good hard whack while it was clamped down to the bench.
Think that works for me at least.
Planished the weld out to stretch the shrinkage from the weld over one of my home made stakes.
This time I removed the weld through coating this strip of steel had before wheeling it and then running the bead. Looks polished!
Just using a tiny bit of 0.9mm/.035 mig wire while fuse welding so the weld will disappear afterwards without thinning the metal. Very little to grind and even less after the first planishing straight after welding and before grinding.
Back together again 230mm/9" wider than stock.
First time I have seen the grille bolted to the guards in 10 years!
Bit of an idea what it will look like once the bonnet is made for it.
I did wonder what it would look like tilted back like the JK's have, but not a fan of the look on this.
