I am restoring / modifying a 69' Vert Ghia. I did mine with a bead roller and finished it off the rest of the tuck with a hammer and homemade dolly. Since I am in the process of widening all four fenders i figured I needed to get familiar with it. Worked out fairly well, just practiced on a few pieces until I was satisfied. I'll practice more when the time comes for the final roll.
Doug My world is flat, as far as engines are concerned. |
#12
#13
If you need a hollow wire edge why couldn't you roll the pocket around
a wire. Do not pinch it completely tight. Then take a slide hammer like they make for dowel pin pullers to pull the wire out. If you had a helper you could assist with an air hammer on one end while the other pulls the opposite end. Don't put the wire in in one piece, use sections to make it easier to pull out. Pullmax made dies for false wire edges but I have never used them
Ron |
#14
