Old 03-27-2021, 02:04 PM
chrisnz chrisnz is offline
Made these hinges after mocking them up with cardboard to check the swing. It was critical that the door move away from the cowl area when opening. I got some 50mm x 10mm flat, bent a right angle into it and then welded a machined tube onto it. That accepted the 10mm shoulder bolt, which acts as the pin.
The internal housing is 75 x 75 x5mm modified to suit the A pillar. I set all this up on a steel plate at the original hinge centers and then used a long pin to line the two up to stop binding
Then cut the A pillar up to accept the hinges
Made a press die to make the hinge covers.
Permanently welded the housings to the A pillar.
Both sides were done at the same time. With these completed, the doors can be tackled next
Chris Woolley
Old 03-28-2021, 04:58 AM
Nicely done
Old 03-29-2021, 09:02 PM
Nicely done
Thanks Marcus
Chris Woolley
Old 03-29-2021, 09:41 PM
Door fitted with hinge pockets temporarily screwed into place to check swing.
Top hinge support rail with dimple for the electric window setup
Lower hinge support and new door bottom
Electric window motor mounting
Outer hinge pockets
Door braced up, ready to rebuild area to suit late model anti burst locks
Chris Woolley
Old 04-01-2021, 01:03 PM
After completing the door lock area, I turned my attention to the door striker area. While rebuilding that area, I lowered the door frame 2" to allow for my roof chop. I wanted to keep the repairs localized.
Early stages
Completed left and right sides
Chris Woolley
Old 04-01-2021, 01:46 PM
dwmh dwmh is offline
MetalShaper of the Month May 2018
Nice work Chris, it's going to be the business. You've obviously planned it all out.
David Hamer
Old 04-02-2021, 02:15 PM
Thanks David. I have got an overall plan. I just need to piece it all together.
Chris Woolley
Old 04-02-2021, 02:26 PM
These bodies originally unbolted through the floor and A pillar. Then there was a cover plate that hid the bolts on the pillar
I deleted the bolts and fitted a new piece in place
Chris Woolley
Old 04-03-2021, 04:42 PM
Made a press die out of 16 x 16mm to make a top hat style extrusion. These top hats go between the floor and rear cab brace. I guess they originally gave the floor some extra strength.
Then we had to make the seatbelt mounting points
Now that the cab is strengthened up I can look at getting the outer doors tidied up.
Chris Woolley
Old 04-05-2021, 03:38 PM
After looking at a heap of roof chops, I thought the best way forward for this cab, was to lower the roof the 2", but rather than split the roof and move the front portion forward, I decided to lift the A pillar up to increase the radius. I wanted the door top to flow nicely. That meant that the A pillar, in relation to the cowl, was laid back more. So to do the door top, the same process was needed
This panel was made in the swager using different radius dies. The larger radii was put in first, dressed up, then the smaller detail line last. This panel was needed to make the contour line meet up with the top portion
To get the opening to flow, I cut a paper pattern of the original glass area, took the 2" chop out, realigned the inner edge of the skin and then transferred that onto an MDF pattern. I used that pattern to rebuild the top door skin to. The glass is having it's frame ditched for a cleaner look. The lower skins will be completed next. These will be made because I am fitting the XJ6 Jaguar exterior door handles, need to delete the original door hinge cutouts and there is rust in the lower skin
Chris Woolley
