Old 10-05-2021, 02:40 AM
shmbry shmbry is offline
Default How to maintain position on Buck ?
Hi
I've come across a lot of information regarding making bucks, and on shaping.
However my problem is, having shaped the material how can I be sure I'm checking on the same place on the buck each time.
Each time I move material I can't be sure the piece is sitting on the same point I last checked, or whether I've just made it worse or better.
Does anyone use location pins or some other method?
Steve Hembry
Old 10-06-2021, 08:57 AM
Originally Posted by shmbry View Post
Hi
Pins work. Brads. Screws.
Tape, with pen marks on tape.
Also to consider is that the panel will re-orient a bit during shaping passes. Sometimes you fight that.
Sometimes you celebrate that.
"Trim" can be non-trivial. Sometimes 3/8" is adequate. Then again, 1/2". Or 5/8".
I had a difficult job one time, aerospace, and L-M specified "one inch of trim" - damn - when shrinking some edges severely it meant double-severely in the trim zones - just to get lopped off later. Blech.
Really had to keep those panels oriented spot-on .... but they passed all the inspections .... whew! (tape w/pen marks).
