Old 08-31-2018, 01:00 PM
vroom vroom is offline
Default valley forming
I am making a panel to form 4' long valley. So far I have rolled the bottom of the valley using my e wheel and slick tire set-up. Next I began forming the wings (sides) in my hammer using a linear stretch die. As the panel began to arch down I began to think about the different stretching methods. This is how I understand them:
With regular dies the panel stretches in all directions radially from the impact site.
With linear dies the panel stretches perpendicular to the impact site so less stretching is required to get the valley to arch.
When you are stretching in an e wheel the material stretches parallel to the axle of the wheels (anvils) so it won't do the job for getting a valley to arch.
I think this is correct but I could use some reassurance.
Tim Freeman
Old 08-31-2018, 05:28 PM
Corrections IN CAPS below, as I see the issue:
With regular ROUND CONTACT AREA dies the panel stretches in all directions radially from EACH impact site. LOTS OF RADIAL HITS EQUAL FEWER LINEAR HITS SO LESS TIME IS INVOLVED AND THE METAL IS SHAPED MORE DIRECTLY/EFFICIENTLY.
With linear dies the panel stretches perpendicular / AT RIGHT ANGLES to EACH impact site so less stretching TIME is required to get the valley to arch, IF THE CONTACT AREA IS LONG ENOUGH.
When you are stretching in an e wheel the material stretches parallel to the axle of the wheels (anvils)/ DIRECTION OF TRAVEL so it won't do the job for getting a valley to arch AS EASILY.
Old 09-01-2018, 01:08 PM
Thanks Kent
A little more clarity
Tim Freeman
