  #31
Old 03-18-2011, 01:11 PM
Oh we're reading David. Trust me on that!
Old 03-18-2011, 04:22 PM
Dave Hatcliffe Dave Hatcliffe is offline
Every single word and spending hours looking at the photos!
Thanks again for sharing David.
looks like my 1925 Austin 7 rebody is due in soon so we can post its progress on here too!
regards
Dave
Old 03-18-2011, 05:57 PM
robert robert is offline
cant wait to see and hopefull learn some about the welding
robert veldman
Old 03-18-2011, 08:52 PM
redoxide redoxide is offline
Still reading, infact I think ive read it at least a dozen times , great work love build ups and lots of info...
Ian
Old 03-20-2011, 02:23 PM
Thanks for the feedback guys, I will post some more tomorrow.
Old 03-20-2011, 02:53 PM
Sollis Sollis is offline
you under the radar man , Thanks for posting good stuff
Old 03-21-2011, 02:32 AM
Michael Michael is offline
Thanks David , I hope you can get a good picture of the flame adjustment you use to weld brass. I was taught never to use an oxidizing flame on my torch ,but I never tried to weld brass. I am very intrested to see how this is done. Great thread, yes I'm reading it .
Michael
Michael
Old 03-21-2011, 02:56 PM
Welding brass is not straightforward. You need an oxidising flame to weld it. I show how to set up the torch on my youtube footage. I have always used pre-fluxed rods but this does not give a perfect colour match which does not matter for the shells I make because they are chrome finished. I have always been able to metal finish the parts which is more important. The flux has been changed recently and now I am experiencing cracking when dressing out the weld. I am using the last of the old rods on this shell. I am experimenting to see what else will work- but for now...
The parts are tacked together at regular intervals..
Then seem welded- The problem with welding brass is that bras is made up of copper and zinc the zinc melts at a lower temperature than the copper and leaves holes in the surface of the joint. This is called volatilization.
The welds I get are never very neat but they are going to be ground off anyway. The weld pool seems to have a life of its own. I try to have a fair bit of build so that any porosity is in the bead of the weld and will be ground off, this does not always work but it prevents too many pinholes.
Here is the inside of the weld.
I very carefully grind and sand both inside and outside of the weld to make it the same thickness as the original sheet. This is a very time consuming part of the build.
Old 03-21-2011, 05:26 PM
Barry911 Barry911 is offline
Fasinating stuff David. I'm guessing you've had quite good value out of that buck now .
Old 03-22-2011, 03:04 AM
wayne080866's Avatar
wayne080866 wayne080866 is offline
Hi David, I just love reading your posts , the info you and the pics are fantastic ..is there any chance of oneday doing detailed dvds on this sort of thing as I'm sure plenty of people would buy them .. me for one.
Wayne
