Old 01-22-2021, 08:01 PM
Hi,
To help with your issue, you can try this. If you pre-thin the material at the bend line, you can get a crisp bend in a machine like yours. To thin the bend line, you can use two tight radius dies in a bead roller, pullmax or with a corking tool by hand. A simple experiment in your material will tell you "how far" to thin, for the tight crisp line you are looking for.
B
Bill Tromblay
Old 03-03-2021, 11:52 PM
RCinHB RCinHB is offline
When bending a long piece, insert a 6 inch (experiment w/ length and thickness) wide shim between the underside of the workpiece and the bending leaf to limit the bending of the workpiece to the width of the shim. Incrementally slide the shim back and forth along the length of the workpiece making a local bend at each location using the leaf. The shim allows the full length of the workpiece to be clamped, but provides a small bend length so as not to excessively deflect the structure. Taper or radius the sides of the shim so they do not mark the workpiece. It is a process somewhat like hammer forming but you are locally bending with the brake instead of a hammer.
Richard Chandler
Old 03-04-2021, 10:54 AM
mark g mark g is offline
Metal Shaper of the Month, April 2011, December 2012, May 2016
Interesting concept.
Mark
www.markgoodenough.com
Old 03-04-2021, 06:49 PM
You have actually done it this way or is this an idea you are presenting to try out ?? ~ John Buchtenkirch
