#1741
I need to replace the original exterior door switches. The CTS had electronic touch pads rather than mechanical door handles. The originals (Pictured split open on the right) were too big to use so I need to replace them with the smaller momentary push button switches
The problem is, the original performed two separate functions. Most likely when pressed the switch activated the door latch and also activated the drop down feature for the side window. After studying the printed circuit on the original, it was clear that the engineers wanted these two circuits to remain isolated from each other while at rest. Only to be connected when the button is pushed. In order to get function without sacrificing form, I needed to separate the switch from the actuator.n I'll use a 16mm momentary push button mounted in the mirror stands, then a couple relays inside the door to keep the two circuits separated unless activated. This is what I came up with. Typically, a relay is used to convey a heavier load on the power side (+) but in this application the switching is done by connecting or disconnecting the ground (-). You can see in my crude diagram below that there is 12v+ going into the relay coil, through it, and to ground-. This activates the coil creating an electromagnet which pulls the contact across from it and completes the circuit. The 12v+ that activates the magnet never comes in contact with anything else. The wires connected to the other side are isolated and can be either positive or ground. Whatever is needed. I used two separate relays so that the two ground feeds never come in contact with each other unless the button is pushed and connects both of them to chassis ground. This is the new rig that will replace the original touch pad. Button locations on both sides. Discrete but easy access. Both mirrors finished and installed. The rest will be tied in inside the door.
Jack Set a Goal So Big That You Can't Achieve It Until You Grow Into The Person That Can. Last edited by Jack 1957; 04-07-2021 at 09:42 PM. |
#1742
Great solution to another problem. Is locking the car on a remote?
Chris Woolley |
#1743
Nothing has changed with the latches or locks. Lock from inside the vehicle with the buttons on the power window switch. Lock or unlock from outside with the fob.
#1744
Raymond posted a woody cadillac that I think is super interesting as well.
Mike Mettelka Mettelka Craft Metalshaping Wanted, 41 Cadillac Fleetwood |
#1745
This one?
#1746
What the hell Jack? I have been waiting outside for 8 days since I read this. It rained on me all day today. I am beginning to think that you may have been kidding about waiting by the mailbox.
Norman |
#1747
This one?
Funny. My first thought was Rolls Royce
Paul Last edited by snedboy; 04-09-2021 at 11:48 AM. |
#1748
No its one that he did a while back but got reposted.... I'm having trouble uploading it to the forum.
#1749
Ask him to do it as a two door wagon.
#1750
Jack, this whole build is just amazing. I've (We've) never before had a chance to follow a day to day build of a Riddler class vehicle. I was keeping up with all the sheet metal and body work but the number of details and the way you worked them out is just stunning to me. World class car you are building Jack. WORLD class!
Regardless, it is an amazing accomplishment. I hope to see it in person some day.
