Go Back   All MetalShaping > Metal Shaping Projects > Beginner Projects
  #31
Old 10-26-2021, 05:19 PM
Originally Posted by Nate S View Post
I was 75% done with welding the panels together when I learned that I probably should be using 1100 filler with the 3003 panels.
would 1100 filler have prevented some of this?
Hi Nate,
Hmmmm ... sounds like you started tig welding 3003 with 4043 filler ...
Right?
Hard and brittle welds, right? Hard to file and hard to bend without cracking?
Dark weld lines/seams?
Yep. You got 4043 filler - which is GREAT for welding aluminum castings.
Otherwise, for welding 3003 sheet (and 1100 sheet) you "always" use 1100 filler - or thin snippets off your sheet - or use fusion welding (autogenous welding, Scot welding, etc).
Keep right on re-welding. You are in a big club, now.
Old 10-26-2021, 11:08 PM
While I think alcohol is safer than acetone either is safe for welding imo. Brake cleaner can turn to phosgene gas and I would never use it before welding.
Dont think acetone is a chlorinated hydrocarbon. If I find out acetone can create gas I will stand corrected and stop using.
Greg
Old 10-27-2021, 07:06 AM
Nate S Nate S is offline
MetalShaper of the Month January 2022
Hi Nate,
Right?
Yep, yep, and yep! 4043 is exactly what I was using. Now that I know a little more its hard to ignore the difference. Cracks aside as you mentioned filing and even planishing is difficult. I learned my lesson!
Nate S - Instagram: @hammerformed
Old 10-27-2021, 09:52 AM
DarkLightning DarkLightning is online now
Acetone contains only carbon, hydrogen and oxygen; no halogens are present. Once it flashes off, you're good to go for welding.
~Steven
Old 10-27-2021, 11:38 AM
Hi Greg,
I checked on acetone having chlorine - Nope. Safe for weld prep.
"Some of the commonly known chlorinated solvents include:
  • Dichloromethane (DCM)
  • Vinyl chloride (VC)
  • Dichloroethene (DCE)
  • Tetrachloroethene (PCE)
  • 1, 1, 1 – Trichloroethane (TCA)
  • Trichloroethene (TCE)
  • TetrachloromethaneCT)
  • Trichloroethylene (TCE)"
https://www.mvorganizing.org/what-ar...inated_solvent
Funny thing that I read a few welding articles some years back that listed it - along with brake cleaner and TCE as being a chlorinated hydrocarbon.
Thanks for the clarify!
Old 11-19-2021, 03:07 PM
Once the wire edge was complete (and repaired) it was time to drill rivet holes for the bottom pieces. As much as I wanted the entire body to be one piece it just wasn't going to be possible with the chassis. I wasn't too sure about the rivets but I think they will give it a "period" look haha.
Old 11-19-2021, 03:33 PM
This is kind of an update dump so I apologize. I'm a little behind in my updates.
The car is FINISHED! Well at least for now. It may never truly be finished haha. Once the rivet holes were drilled I began the process of sanding and fine tuning highs and lows. Then I finished everything off with the maroon scotch pad and alcohol. I am really happy with the finish it left. Its plenty smooth enough that you can tell this was my first metal shaping project, but not mirror like so that even the tiniest imperfection has a neon sign lol.
More importantly my daughter loved it! Now all I hear is "I wanna go fast in my race car!". And she usually wants to put on my outdated open-face helmet to do it .
Old 11-19-2021, 06:44 PM
Attachment 61769
Attachment 61770
Attachment 61771
Attachment 61772
Gold Star, Nate.
Old 11-19-2021, 08:06 PM
So cool! So cute! With that helmet on, I'm reminded of Danica Patrick!
~Steven
Old 11-20-2021, 02:48 AM
Beautiful car and wonderful driver.
