  #91
Old 06-06-2017, 04:22 AM
The beading you did around the louvres really sets it off.
Old 06-06-2017, 01:06 PM
Very fine project, and the paint did not overwhelm the metal work.
Old 06-06-2017, 10:27 PM
Gorgeous looking car.
Old 04-29-2020, 10:36 AM
MP&C's Avatar
MP&C MP&C is online now
Had a visitor in the shop yesterday, collaborating with Cody Walls of Traditional Metalcraft (Milton, DE) on adding some louvers to an Austin Healey project he has in his shop. We got the bonnet done yesterday, and I had to modify my radius fixture for the boot as it had too much crown to simply louver while flat. So that is yet to come.
Time lapse:
https://www.youtube.com/watch?v=Y0zjX58BDgM
Modifying our radius fixture for louvering the boot:
https://www.youtube.com/watch?v=2_0rl50XxzM
Here's pictures of the project car in Cody's shop for reference. Photo credit Traditional Metalcraft. Follow the progress on his build @eastcoastchanneljob on IG or Traditional Metalcraft on FB. This car is sporting a Honda S2000 drivetrain, should be a handful..
Robert
Old 04-29-2020, 01:24 PM
Overkill Overkill is offline
Default Bravo
Your work is always impressive!
Ron Covell, Autofuturist books (Tim Barton/Bill Longyard) and Kent White metalshaping DVD's available, shipped from the US. Contact lane@mountainhouseestate.com for price and availability.
Old 04-29-2020, 06:07 PM
SATAUS SATAUS is offline
MetalShaper of the Month July 2010, Dec 2011, Nov 2014, Feb 2016, March 2021
Thanks for sharing Robert some good information/ideas there.
Scott
Old 04-30-2020, 05:14 AM
That came out perfectly.
Old 05-14-2020, 06:48 AM
MP&C's Avatar
Thanks guys!
Cody set the hood (bonnet) on the Austin Healey to get a look see on the louvers....
…..and this past Tuesday he came back to the shop so we could finish up the louvers in the trunk lid (boot). I must say this was the most involved and challenging louver job we have done so far. The trunk lid has a lot of crown, and with a 6” rise in the center, we needed to use the rotation fixture ala Mini Cooper wheel hub. We added to this a hinge mechanism to allow rotation up and down. The limits of the machine's throat height and high crown also meant we'd have to punch half the louvers from back end first, then rotate the lid and tooling and approach the rest from the front end. Now given the extreme flex/twist that the .050 aluminum is prone to, we needed to make sure the cut pattern would be parallel to the last set at the point we rotated from front to back. This required some "gusset" straps clamped in place to limit the twist.
Before this was added, any twist of the panel would change the outer limits of the cut +/- 1/4". Here's the wheel hub arrangement along with the hinges for up and down adjustment. We needed adjustments along 3 different axis to be able keep all the louvers running true and parallel.
….and we're off....
At this point we were 4 hours in to measuring, clamping, test run (drag the cutter against the panel to scribe the location), rotate 180 front to back, and test the pattern again, just to get to where we could start cutting. …..and another 4 hours to go before we finished. All told, with the time Vince and I spent Saturday working out clamping methods and other details, the layout was approx 4 times that of what it took to do the actual cutting.
….and the time lapse video of the process..
https://www.youtube.com/watch?v=NMmm...ature=youtu.be
Yesterday Cody sent me pictures of the trunk lid installed.. These louvers really change the attitude of the car... Badass....
Robert
Old 05-14-2020, 09:59 AM
Pehr Pehr is offline
Default Kool
Really, really impressive job
Pehr Norström
Old 05-14-2020, 01:05 PM
Default Great Job
Very, Very nice.
Reminds me how much I have to learn.
