Forming concave cones from sheet brass
Hi,
I'm a brass instrument hobbyist, and I do some fabrication. One style of horn I've been working on is the sackbut--a Renaissance trombone. These have a "kranz" or "garland" around the bell to add support. They look like this: I've formed them by silver-brazing lamp banding into a circular shape, annealing, and then forming on a mandrel with a big rawhide mallet, but the result is always uneven and not very pretty. I have one of those cheap "english-wheel-shaped objects." Is there a technique I can use--either before or after silver-brazing the ends together--which will result in a prettier kranz?
Shwabra |
I have seen several videos on YouTube of musical instrument repair. One video showed a special EW with many attachments for narrow openings. Everything is easy to make. I don't remember the address of the video anymore. I have similar extensions for different situations. My EWs are very variable. In some cases I use very small bearings and polyurethane and plastic wheels. They don't leave a mark.
Edit your EW a bit. Add some profile to make them less flexible. With flexible wheels, you don't have good control when shaping. Before welding the reinforcement, pre-tension the frame with a strap. The wheels become very strong. Your shaping result will be greatly improved. https://www.allmetalshaping.com/showthread.php?t=20883
Jaroslav |
The best way i have seen them made is from flat sheet folded in half then raised over a mandrel. I have made similar shapes the same way, spinning would be another good option. There used to be a good video on youtube but i cannot find it.
Paul |
While I've hand raised such forms from flat sheet rolled into a cone with the seam soldered I found spinning a better process. I've attached a couple of items I've spun in the past with the first being similar to the end bell which I think is what you're trying to improve.
David Billington |
