  #1661
Old 01-19-2021, 11:32 AM
metaldahlberg88 metaldahlberg88 is offline
I'm nervous just reading about it. haha
- Tom D
Old 01-19-2021, 12:56 PM
daveb daveb is offline
I’m not sure if I missed it somewhere, but what bit did you use to cut the glass ?
Thanks for posting the work you do !!
Old 01-19-2021, 03:52 PM
I used a 40 grit diamond bit. 1/4" shank 1/8" cutting diameter. See post #920 on page 75.
Old 01-19-2021, 04:22 PM
SATAUS SATAUS is offline
MetalShaper of the Month July 2010, Dec 2011, Nov 2014, Feb 2016, March 2021
Nice job Jack and thanks for the information.
Scott
Old 01-21-2021, 07:07 PM
Thanks Jack!
Old 01-23-2021, 09:10 PM
The new bit came today so I jumped back on the windshield. I finished cutting the left side then sanded the edge smooth. No cracks or problems. That's a load off my mind.
This is Armour Etch. It's a very strong acid used to etch glass. It actually erodes the glass surface and leaves a flat, slightly coarse surface that allows paint to stick tight. No flaking or pealing.
The tan colored tape is plastic like packing tape and really keeps a tight seal. The acid won't effect it and won't allow the acid to seep under it. It leaves a super clean edge.
The blue tape is just masking tape along the outer edge to prevent the acid from seeping into the plastic laminate between the two layers of glass.
Lots of protective gear for this part. This acid is dangerous. Actually, I'm surprised they sell it retail. Keep a bucket of water handy, rubber gloves, eye protection, ventilation, etc.. You just brush it on, let it set for a few minutes and squeegy it off with a bondo spreader, and wipe the surface with water and a rag. I was doing this in sections about 12 to 18 inches. After it's etched you can feel the slightly rough surface. It has a whitish look to it but once the black paint is on it, that goes away.
After the etched surface is thoroughly cleaned and dried, I just used a Rustoleum black spray bomb to paint it. Enamels are best for unprimed surfaces. It dries slow, it's relatively durable, and it doesn't go brittle over time.
Done.
I'll probably install it tomorrow.
Old 01-24-2021, 04:18 AM
That came up well Jack. Glad you did so well cutting the glass again. I can't remember what you used to sand the edges with afterwards?
Old 01-24-2021, 08:05 AM
What is the purpose of the perimeter glass black out? Glare reduction?
Larry
Old 01-24-2021, 08:13 AM
Default Etching glass
Excellent work Jack. Thanks for posting this seldom shown process. You are wise to fear the glass etching. We do it at work. Typically hydoflouric acid is used. At 20% dilution, a couple drops can cost you a finger. Get it on 10% of your body, it can kill you.
Bill Funk
Old 01-24-2021, 09:21 AM
The windshield will be glued in with urethane adhesive. The black around the perimeter is there so the adhesive can't be seen from outside the car. Same as all the late model vehicles.
