Old 09-02-2014, 07:18 AM
Default 1951 F1 Pick Up Modified Re-Build
Hi All, I thought it would be time for me to start posting a few photos of a current project I'm undertaking...........
The owner purchased the truck from a panel shop who was doing all the work for another customer, who eventually bit the bullet and off-loaded it. The cab was all finished, nice and straight covered in primer and lots of little things needed doing. One would of thought that this would be a good buy! "Right!" The current owner who just bought it thought along those lines. Until I saw it, I said we need to strip it back and see what we have got, How wrong he was.......................That's when my nightmare started.
This was the front guard after it was stripped of all Nicky(Bondo) Fantastic welding repairs were covered over, Total shame! as well as the great wheel clearance.
Fabricated a little flare and tweaked the guards slightly for clearance, as well as cleaned the rust areas
The previous idiot made the floors from 2mm sheet and made them to high and the wrong tapper to the firewall.
Until next submission.
Old 09-02-2014, 08:05 AM
One need to go to a special school to learn to do a job that way
Old 09-02-2014, 11:03 AM
Don't feel bad john. Bought a 56 Chevy p/u here in the states for myself and k knew going in I was going to strip the body to see the body shop work that had been done----nothing but lapped joints tack welded, plates welded on top of holes then bondo over-----looked like more work than actually doing it the right way. So needless to say I'm glad I did the rework. Hope the customer understands and appreciates your work.
George
George
Old 09-02-2014, 05:12 PM
George
The horror stories just keep on ..... don't they? Oh, the stuff we find when opening up some recent work that has a few dangling threads that just NEED pulling ....
Our old saying from the HAC metal resto shop days was:
"a lot of bondo and some paint
makes 'em look like what they ain't."
The fresh tin sure looks good, and I hope the owner appreciates your beautiful craftsmanship, Oldnek. You do have your chops - like the clean finished ends of the beads.
I used to keep the cut-outs for my "rogue's Gallery." ... but then it got to be too much so I kept the worst, and that got to be too much .... sigh.
Old 09-03-2014, 10:06 AM
More Pics..
Size:  54.2 KB Name:  0002 Door Gap.jpg
We think they didn't brace the cab before welding the 2mm floor in, cause the doors would close, and passenger side would jam, The gaps where all over the shop. no wonder they gave up. The Cab had 1.5 inches of twist in it.
Name:  0003 Weld Door.jpg
Size:  31.5 KB Name:  0004 Driver Door Filler Cap0004.jpg
After cutting the floor out, I had to pry and pack the doors to get the 4mm gaps and then welded the doors to the cab, then built internal bracing frame.
The Fuel Filler patch panel shows just how good theses blokes were.
Name:  0005 Front Lower Cowl.jpg
Size:  22.3 KB Name:  0006 RHS Cab Mount.jpg
Here they used 3mm RHS for the cab mount points and ran them along the sills (rocker) panels. These guys had no idea.
Name:  0007 3mm Plate.jpg
Size:  37.5 KB Name:  0008 Patch Adams.jpg
3mm sheet for the inner kick panels, nice and strong on the floor , not the way they did it. The Patch work sill (rocker) panel....There's more sheets in that rocker than a plate of Lasagna
Name:  0009 Cab Frame.jpg
Size:  48.1 KB Name:  0010 Cab Frame .jpg
Bracing frames in and most of the snot cut out, that was a huge job in itself.
Old 09-03-2014, 10:21 AM
More Pics.
Name:  0011 Bog City.jpg
Size:  24.1 KB Name:  0012 Inner A pillar.jpg
Bog City,
Name:  0013 Inner Pillar Mount.jpg
Size:  33.2 KB Name:  0014 Pillar Mount.jpg
Fabbed up the lower Hinge supports out of 2mm CRS and made some new Hinge bolt plates. The same was done for the other side.
Name:  0015 Pillar Mount.jpg
Size:  45.9 KB Name:  0016 Pillar Mount.jpg
Name:  0017 End Rocker panel.jpg
Size:  48.8 KB Name:  0018 End Panel.jpg
Name:  0019 Kick Panel.jpg
Size:  39.0 KB Name:  0020a  Lower Cowl .jpg
Made the inner kicks and purchased the Lower Front Cab Corners and Rocker Panels from Dennis Carpenters (Which are EMS Manufactured)
Only because I didn't know what the originals looked like and how they fit.
Old 09-03-2014, 10:26 AM
And More Pics..
Name:  0020b inner kick panel.jpg
Size:  55.3 KB Name:  0020c  Lower Cowl.jpg
Name:  0021 Lower Cowl.jpg
Size:  48.3 KB Name:  0022 Lower Pillar.jpg
Name:  0023 Firewall.jpg
Size:  51.7 KB Name:  0024 RSide Lower Cowl.jpg
Name:  0024a RS Lower Cowl .jpg
Size:  38.7 KB Name:  0024b RS Lower Inner Frame.jpg
Name:  0025 Lower Rear Cab.jpg
Size:  46.6 KB Name:  0026 Lower rear Cab.jpg
Old 09-03-2014, 10:31 AM
Let me Know If I bore you guys.
Name:  0027 Rear Cab Panel.jpg
Size:  36.2 KB Name:  0028 Rear Cab Panel.jpg
Look out! Action Shot
Name:  0029  Rear Cab Panel.jpg
Size:  30.0 KB Name:  0030 Rear Cab Panel.jpg
Name:  0031 Rear Cab.jpg
Size:  32.8 KB Name:  0032 Rear Cab Panel.jpg
Name:  0033 Rocker end.jpg
Size:  44.8 KB Name:  0034 Rocker End.jpg
Name:  0035 Rocker Panel.jpg
Size:  49.7 KB Name:  0036 Rocker.jpg
Old 09-03-2014, 10:35 AM
And More..
Name:  0037 End Rocker.jpg
Size:  30.8 KB Name:  0039 Rear Cab.jpg
Name:  0040 Rear Cab.jpg
Size:  31.7 KB Name:  0041 Rear Cab.jpg
Size:  37.9 KB Name:  0043 Trim.jpg
Name:  0044 Rear Cab.jpg
Size:  46.0 KB Name:  0045 Firewall.jpg
Name:  0046 Tunnel Brace.jpg
Size:  29.6 KB Name:  0047 Tunnel Brace.jpg
Old 09-03-2014, 10:47 AM
Yes More................
Name:  0048 Tunnel Brace.jpg
Size:  44.4 KB Name:  0049 Tunnel Mount.jpg
Name:  0050 Tunnel end Piece.jpg
Size:  25.5 KB Name:  0051 Tunnel Wheeling.jpg
Tyre tube works great for rolling on the wheel.
Name:  0051a Wheeling Floor Pan.jpg
Size:  32.6 KB Name:  0052 Wheeling Floor Pan.jpg
Apologies for no pics on the bead roller, My photographer had to go to school.
Name:  0053 Fitting Tunnel.jpg
Size:  37.6 KB Name:  0054 Rear Pans.jpg
Name:  0055 Rear Floor Pans .jpg
Size:  38.2 KB Name:  0056 Pass Cab Mount.jpg
The floor is looking a dam site better than what was previously fitted in there.
At least 6 times lighter as well. Cabin mount points where incorporated as part of the firewall. I did it this way cause I think it looks neater, and gives it a 2014 Factory look.
