  #141
Old 02-10-2021, 06:29 AM
Good stuff.
Old 02-17-2021, 07:37 AM
Question
Thanks !
Next update!
After the welding primer dryed out, it was time to tack weld the airbox, only a couple tacks at the beginning to check it assembled:
Seems to fit good:
Then I put the repro "tunnel" for the back part..and it was totally wrong. I compared it with my original..and for sure it was way off...
I then made some cut to "adapt" it:
and welded some tab to keep the position:
Then it was a matter of filling the space by creating the missing part and tig welding it:
now it fits:
and then I removed the old storage primer, put some primer on it and then some paint in the OG color except where welding comes (I put there some welding primer!):
and then some on the body counterpart:
Antoi
Old 03-12-2021, 05:18 AM
So, a bit to report on that front
After the paint, time for some welding primer on the body:
Then the firsts tack weld:
And check with every surrounding parts:
And Then fully welded:
Voilą
Old 05-29-2021, 11:36 PM
Some progress to report finally !
I made some progress on my 60 only (screw connections!) horns:
As received:
Disassembly:
Sandblasting, inclusive the screws:
Fresh paint and reassembly:
So, second one is done:
Now to work on the shell to have somewhere to screw them in
And then started to create some metal patches:
Here we see the rust:
So preparing some steel:
It first gets worse..
And then better:
Then it was time to put the beads.. All the material pictured here:
And here we go:
Now some fine tuning left and it will be ready to weld, but I will weld it when all the surrounding is ready:
Stay in touch, news coming soon !
Old 05-30-2021, 06:12 AM
I noticed the screw slots are all dialed in.
Nice job on the patch.
Old 05-30-2021, 08:55 AM
Nice work Antoine. (And a lot of it!). When you are finished with the structural welding I suggest you fog the potential water trap areas with cavity wax using this type of extension. The brass tip on the end of the hose has tiny holes drilled in it and shoots a mist of wax that stays soft. It will seep over time and surround your plug welds. It's flammable so wait till you are finished with welding to apply.
Old 06-03-2021, 11:26 AM
Good eyes Pugsy
Jack, thanks for the advice, will use it !
I promised you to bring fast the next update.. So here we are!!
Next patch in preparation before a big welding session ops:
Here the rust:
Template in preparation :
Cutting some metal:
First bend:
And starting with the bead:
And here we are:
Stay tuned for the next update,
Old 06-03-2021, 06:10 PM
Nice work Antoine!
Old 06-04-2021, 05:36 PM
pistol pistol is offline
That panel turn out great .love the work your doing bring this ghia back to life
Cheers Paul
Paul
Old 06-05-2021, 07:07 AM
devin1 devin1 is offline
Nice job Antoine, keep it up!
Devin
