  #31
Old 11-20-2010, 11:38 PM
fred26t fred26t is offline
Default Sollis that is all awesome!
Who what great work. I am a real novice but you sir are a master. Fred26T
Old 11-21-2010, 05:18 PM
DaveAuer DaveAuer is offline
Hey Sollis,
Great to have you back your work is AMAZING! I remember you posting pictures of the bagger before it was painted...you are a true artist!
Dave
Old 11-21-2010, 05:31 PM
Very nice work Solis. I notice you bronze weld some of your steel panels is there a reason you do this?
Old 11-21-2010, 10:54 PM
Sollis Sollis is offline
Hi David !
i don't use bronze rod on structural parts some times i use where i want to have parts join together with low melting point but nothing structural
i heard people concern about paint don"t stick i can see where maybe welding with gas and using flux have something to do with that but ts never happened in my experience with tig welding
Old 11-21-2010, 11:17 PM
SATAUS SATAUS is offline
Default bronze rod
Originally Posted by Sollis View Post
Hi David !
Hi Sollis,
Nice work.
What is the bronze rod you are using?
Are you welding it with TIG?
What gas are you using?
Scott
Old 11-21-2010, 11:30 PM
Originally Posted by SATAUS View Post
Hi Sollis,
Nice work.
Scott
just a solid silicon bronze with argon gas and tig i wouldn't join panels and planish its soft and will crack
it also good for something if you don't want you part have weld distortion from the back since its have low melting point it doesn't penetrates true much
Old 11-23-2010, 02:48 PM
tobyflh tobyflh is offline
I'm going to quit metal shaping after i saw all that work. I don't think it gets much better.
Old 11-23-2010, 07:35 PM
not true it always could be better, you can master better skills all the time like work speed ,panel fitting , welding with less distortion, part design make parts with less pieces and much more
i did this gas tank on power hammer just to see if i can do it two part left and right i have buck made
Old 11-23-2010, 07:55 PM
Dutch Comstock Dutch Comstock is offline
Sollis, I have watched your motorcycles over the years. Seeing your works in progress is really excellent.As builders we really appreciate seeing all of the work that you put in to each project and how you go about things. Thaks, Dutch
Dutch Comstock
926 Shells Bush Road
East Herkimer,N.Y. 13350
(315)866-3034
comstockmetalshaping.com
Old 11-23-2010, 08:20 PM
Gleeser's Avatar
Gleeser Gleeser is offline
Metalshaper of the Month, May 2010
I've seen your bikes over the last couple years too. Your work is astounding. Glad to have you posting here. Did you work with Westbury for awhile? I'm not sure I have the right shop name there.
Grant
