Old 03-15-2011, 05:37 PM
yukon cornelius
Guest
Posts: n/a
Default Hello from the North
Hey guys, Ryan here.
I live across the border from Detroit Michigan in Tecumseh Ontario.
Working on building an English wheel now to help me with forming a few panels for my 56 chevy wagon I'm about to get started on. Learning to Tig weld now as well (always used mig).
Cheers, Ryan
Old 03-15-2011, 05:57 PM
Hello Ryan, Welcome to the site. I hope your wheel build goes well, there is quite a bit of info on here about building wheeling machines and Kerry is something of an expert and will give you advice if you need any.
A wheeling machine can only do a a small part of the work on any given panel.
Tig welding has a lot of advantages over mig for joining sections of panels- don't get rid of the mig though you will always find uses for it. (plug welding etc). I prefer gas welding over tig -especially for aluminium. For steel I guess the tig is just a matter of personal choice. (I use both)
Old 03-15-2011, 09:05 PM
Welcome Ryan:
If you don't already have your E Wheel plans firmed up I would suggest looking under the E Wheel thread on this site. You may see something that may alter your design. Look at all posts made by Kerry Pinkerton and I might suggest you get his DVD.
Old 03-19-2011, 07:36 AM
yukon cornelius
Guest
Posts: n/a
Oh, I'm quite familiar with Kerry's wheel design from other forums. It is the style that I am intending to base mine off of. It'll be going together from some 4"x8"X1/4" tubing I got a killer deal on and should be pretty strong.
Thanks for the warm welcome.
Old 03-19-2011, 10:28 AM
Welcome aboard Ryan!
