-   -   New From Chicago, IL (https://allmetalshaping.com/showthread.php?t=10907)
Retribution 02-14-2014 08:42 PM
I suspect you may be able to find a set if you look at the auctions r used supply stores around Detroit.
I remember watching the stylists use sweeps back in the 1980's. It was explained to me that they were actually portions of a giant French Curve but I have also heard they were portions of a parabola. I had to convert the clay model data into CAD and the CAD system I used supported sweeps (only CAD system I have ever seen this in) The CAD system was Ford's PDGS body design system.
Sweeps date back at least 100 years and were used internationally in automotive and aerospace.
All this was explained to me by a few old stylists and body designers when I was a designer.
Can anyone confirm or correct the French curve or parabola info?
Kevin Adams
Kerry Pinkerton 06-13-2014 10:20 PM
I haven't heard that Kevin but there is lots I haven't heard. If you search for sweeps, you'll find several threads that discuss them. Every sweep I've seen has a constant radius where a French curve or parabola has a constantly changing radius.
Most are made by a 1/16" increment in the rise of a chord. 36+ inches seems to be the norm.
Peter Tommasini 06-14-2014 04:31 AM
Hi Kevin welcome to the forum
HEATNBEAT 06-14-2014 06:41 AM
Hi Kevin and welcome!:)
David Gardiner 06-14-2014 01:50 PM
Welcome to the forum Kevin.
Jere 06-15-2014 01:29 PM
Hello Kevin and welcome to the site.
Jere
