Old 11-19-2012, 06:11 AM
ozi jim's Avatar
ozi jim ozi jim is offline
Default 66 Ford
Name:  body off 3.jpg
Name:  body off 4.jpg
Size:  76.1 KBI am new to the site.
I am here because of this car.
I made the roof buck in ply but found it limiting to complete the job with out modifying the buck.
I started goggling and here I am.
Great site with tons of skill.
I want to make the rear/front bucks in wire so I can fit it to the car.
I have been asked to put something up ,this was started 8 weeks ago.
I havnt made full panels before just sections but I am learning fast.
Old 11-19-2012, 06:17 AM
ozi jim's Avatar
Size:  65.7 KBRoof buck
This became limiting when the flanges for the door seals had to go in.
I had to modify the roof trusses this is when I realized the advantage if wire form bucks.
The flanges I folded then used the shrinker /stretcher.
They are welded in.
Old 11-19-2012, 06:24 AM
ozi jim's Avatar
Size:  66.6 KBSill were very easy.
I put a section of inner tube around the top wheel and rolled the profile.
I purchased x6 new 3" and 1" wheels early in the job as my 3 wheels where leaving marks due to excessive crown.
Old 11-19-2012, 06:29 AM
ozi jim's Avatar
B pillars are several sections.
3 face panels and the seal flanges are done on the jenny
Old 11-19-2012, 06:42 AM
ozi jim's Avatar
Inner skins on the roof wheeled out.
I used 3m panel bond to adhere inners to outer pillars and the inner lining.
I dont know if glue is a no no on this site but it on this job panel bond is magic.
When it was assembled I foam cored the roof and pillars.
Name:  b pillar glue 2.jpg
Name:  roof inner 2.jpg
Name:  BONDING A PILLARS 3.jpg
Old 11-19-2012, 06:59 AM
ozi jim's Avatar
The doors have been a mission.
I have not kept count on the hours because it might scare me .
Old 11-19-2012, 07:09 AM
ozi jim's Avatar
the upper inner roof panel I tried to simulate was is their but not to exacting detail.
I then made the roof skin.
I have made the pillar skins but have not got pic.
I have the other door to do but I think I will make the rear wire form buck first as I need a break before I start the second one.
Im glad its a 2 door.
I will keep posting over time.
Name:  door roof 1.jpg
Name:  door roof 2.jpg
Name:  door roof 3.jpg
Old 11-19-2012, 07:25 AM
ozi jim's Avatar
I have made a long profile gauge out of 4 gauges.
Wire bucks
I have looked at a lot of pics and get a good idea how to go about it.
I am thinking 5 or 6 mm wire should be enough.
Some members are using heavier.
Any advice is welcome.
Jim
Old 11-19-2012, 08:44 AM
Very nice Jim!
66 Ford what car is it?
Old 11-19-2012, 09:31 AM
Jim, thanks for posting the pictures of your GT-40 project. Looks like you are making good progress on the body. What aluminum alloy are you using, 5005?
