Old 10-31-2017, 09:57 AM
Default 35 Ford Truck Door skins
In progress, but started on them over the weekend...
I gotta make two lower skins for a 35 ford truck. Here's where im at so far.
Perimeter buck made with captured sweep info
rough skin wheeled up
machining belt line dies
test run.. still needs tuning here..
before I did a test run, i scribed lines 6" apart. after running i noticed they drew around .125 closer... this was the amount of pre stretch I put in after.
close
door hinge detail.
stamped
as of last night... still some work to do, and i gotta make the opposite door.
Old 10-31-2017, 10:17 AM
MP&C's Avatar
MP&C MP&C is offline
Beautiful work Steve!
Old 10-31-2017, 11:05 AM
blue62 blue62 is offline
Very nice clean work!!!!!
Dave Bradbury
Old 10-31-2017, 11:48 AM
Nice work! out of curiosity why did you go for male+female press tools rather than just a female and use a urethane pad? Do the dies you made coin at the end of travel?
Paul
Old 10-31-2017, 11:51 AM
Thanks everybody for the kind words.
I have a CNC mill is the main reason. I can CAD/CAM and send it away and walk back in an hour. The dies I made are designed with .035" clearance all around.
Old 10-31-2017, 12:43 PM
bobadame bobadame is offline
Really nice clean work. You're using 20 gauge?
Bob
Old 10-31-2017, 12:55 PM
Looking good steve. That is a door skin to be very proud of.
I agree very clean details.
Old 10-31-2017, 01:54 PM
Nice work. Did you weld the upper and lower dies to square shanks or put them in setscrew type holders so you could move the pressure point by moving profiles fwd/aft in the machine?
Greg
Old 10-31-2017, 02:33 PM
Attachment 43837
Attachment 43838
Attachment 43839
Attachment 43840
Attachment 43841
Attachment 43842
close
Attachment 43843
door hinge detail.
Attachment 43844
stamped
Attachment 43845
That is a peach, Steve! Clean surface and crisp details. Very good to see.
Old 10-31-2017, 03:02 PM
longyard longyard is offline
Steve, you just go from strength to strength. Congratulations!
Bill Longyard
Winston-Salem, NC
