Go Back   All MetalShaping > Metal Shaping Stuff For Sale > Heads Up Announcements
Old 05-10-2017, 12:58 PM
Default Clecos
Anybody know what these are?
https://www.k-bid.com/auction/19830/item/46?offset=46
Bill Funk
Old 05-10-2017, 01:25 PM
cvairwerks cvairwerks is offline
I see some standard clecos, a couple of "F" style cleco clamps and a couple of butt joint clamps. If the standard ones are copper colored, they are for #30 holes. $10-15 for the lot maybe. New, about $.50 each for the standards, $7-9 for the pliers. The "F"s are about $2 each. The butt clamps run about $3-4 each.
Craig
Old 05-10-2017, 03:40 PM
Agreed on that, for both parts and price.
Old 05-13-2017, 02:15 PM
Jim Tomczyk Jim Tomczyk is offline
Originally Posted by billfunk29 View Post
To answer your Question - In case you wanted to actually know what they are and how they are used. They are " re-useable pins" used to hold and or align sheet workpieces together (through which holes are drilled ) - most often utilised when riveting sheet / workpieces together but can also used in many other ways to align and hold work in place - by example see link below
https://youtu.be/8jTwPmSsrgk
Jim
"I have not Failed - I've just found 10,000 ways that have not worked" - Thomas Edison
Old 05-14-2017, 09:42 AM
Good eye, Jim. Missed the point on that one, for sure...
Clecos in action ... holding stuff until it gets screwed or riveted.
Old 05-16-2017, 04:09 AM
You guys are so lucky - twice the price + in the UK
Jim
Old 05-16-2017, 01:17 PM
Jim: Those are average used prices. New would 50% or more higher, depending on where one shops and the quantities purchased. At work, we've bought probably several million between the various sizes and styles since the place opened in 1942.
Craig
