Go Back   All MetalShaping > Miscellaneous stuff you need to know > Comments and Suggestions
Old 01-11-2010, 02:48 PM
Default is there a way to download a complete thread ?
Hi
I was wondering if I can download a complete thread including pictures,
say I wanted to study Group Design Reciprocating Machine thread on a plane flight,
Any way to do it ?
thanks for the info
Chris
Old 01-11-2010, 05:48 PM
Well...kind of.
You have to do a page at a time but you can set your page length in your user CP.
Just go to your browser edit function and do a 'select all' then paste into the word processer of your choice. You get a bunch of stuff you don't really want but once in a word document or whatever, you can edit out the headers etc.
Old 01-11-2010, 06:11 PM
thanks
I will try that once I get my desktop computer going again,
using the netboot now
Dave
Old 01-11-2010, 06:26 PM
That is basically what we did when we moved the content from the OLD free site to this one. Over the years, I've saved several things like this.
Old 01-11-2010, 07:44 PM
tdoty's Avatar
tdoty tdoty is offline
I have save a BUNCH of stuff just as Kerry described.
I'm still trying to find out how Ryan has the HAMB set up to "view all" posts/pages in a thread as one. Make saving much easier. Alas, I haven't had any luck yet.
Tim D.
Old 12-05-2014, 11:31 AM
VetteMemphis VetteMemphis is offline
Just ran across this thread and would like to add...
If you have AdobePro on you machine, you'll find a "convert" button in the upper LH corner of your browser screen, immediately below the menu bar.
Use that button to create a pdf of each thread page, saved to wherever you chose in your machine.
I've saved a ton of stuff like that and am grateful to have it for now.
Will miss it once I retire, however.
Bruce
Old 12-07-2014, 03:02 AM
Another way is, if someone with a Ipad like to do this kind of readings when you are offline is to take screendump and then look/ read the "photos"
To do a screendump just hit the "home button" and the "on/off button at the same time.
It will be saved as a photo so it is easy to read and if needed zoomed too.
Cheers!
Per
www.metalmansweden.com
Old 12-07-2014, 05:36 AM
Janne Janne is offline
I just always print, the page in a .pdf form.But you have to take every page, invidually..but it is pretty easy to do ..
Janne Jarvinen
--------- JJ ----------
